ae92 speedometer issue
Postby Jingle Balls » Thu Jul 30, 2009 9:35 pm
Hi all
I've read a few existing threads on this topic but i'm confused and not really sure what I need to do.
I have an ae92 with the digital dash, which was running fine until all of a sudden the speedo stopped working. Now I read bits and pieces about that ae92 uses a mechanical (does this mean cable?) as opposed to electronic sender and signal. But does this apply with my digital dash model?
What's likely to have happened, and what would my first thing to attempt to resolve be.
Jingle Balls
Postby gasman » Thu Jul 30, 2009 11:39 pm
find out if there is a cable coming out the back of the gear box or a plug with some wires coming out of it. that should give you an indication of how it works.
"What can possibly go wrong?"
gasman
Postby whynot » Fri Jul 31, 2009 6:57 pm
my ae92 has a digi dash with a 2 piece cable drive to the back of it, the bottom one broke not long ago. Got a 2nd hand one greased it up and it is good as new
whynot
Postby Paulio » Fri Jul 31, 2009 8:14 pm
Toyota has made the 2 piece speedo cable with a weaker link part on purpose, so if it snaps, it snaps in an easily accessable area. Ive actually snapped mine doing a huge boost! Took 1 minute to replace.
You can check it yourself, to see if it is the culprit or not. Simply find the speedo cable on the top of the gearbox near the back, its the only fat cable sticking out vertically. You will notice it is held in by a cap that you can undo with your fingers, it has grips, then 30cm up the cable there is a join, with the same cap that you can undo. That is the weaker link part of the cable that can snap, the piece that you want to check out.
Dont worry, its safe as. Play with it, you will know if its broken.
I have a spare one I think, if you need one.
Otherwise buy someone a pack of townies or box of piss to diagnose the problem.
Paulio
yees booy
Paulio
Postby Crampy » Fri Jul 31, 2009 8:32 pm
Here's what happened to my AE92. Easy enough to fix. Unscrew from gearbox and seperate this portion from the rest of the cable.
Crampy
Postby themaleman » Sat Aug 01, 2009 12:44 am
mine has snaped twice and once i snaped the actual wormdrive in the box. hopfully you havnt. was costley for me as the 4agze box used a different wormdrive to the common 4age 1
manual 80 series cruiser
4agte ae92 Levin
a15 powered sj410
themaleman
Postby Santa'sBoostinSleigh » Thu Aug 20, 2009 3:31 pm
Crampy wrote:Here's what happened to my AE92. Easy enough to fix. Unscrew from gearbox and seperate this portion from the rest of the cable.
http://i141.photobucket.com/albums/r69/ ... C00006.jpg
pretty sure thats the same thing that happened to mine, right before the drive down to Manfield, where i managed to blow the engine up :'(
Santa's Mega Sale
Santa's TardMe Listings
GTFX: viewtopic.php?t=67655
Postby tsoob » Fri Aug 21, 2009 10:18 am
Paulio wrote:Toyota has made the 2 piece speedo cable with a weaker link part on purpose, so if it snaps, it snaps in an easily accessable area. Ive actually snapped mine doing a huge boost! Took 1 minute to replace.
Paulio
I have this exact problem, do you still have that spare>?
Nick
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
WHEELS, TYRES & SUSPENSION!
www.platinumwheels.co.nz
tsoob
Postby themaleman » Fri Aug 21, 2009 11:50 am
and i think this part is interchangable between all ae92's as my gtz used 1 from a non supercharged ae92
4agte ae92 Levin
a15 powered sj410
themaleman
Postby Jingle Balls » Fri Aug 21, 2009 2:48 pm
yaeh thanks guys. have fixed it. was surprised that its cable driven being digital.
Jingle Balls
Postby Paulio » Sat Aug 22, 2009 2:41 pm
tsoob wrote:I have this exact problem, do you still have that spare>?
Nick
Yeah bro got it here if you want it, ill courier it up to you on monday?
P
yees booy
Paulio
Postby tsoob » Mon Aug 24, 2009 12:17 pm
Nick
P
please bro that would be so awesome.
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
tsoob
Postby Paulio » Mon Aug 24, 2009 12:55 pm
Sweet as bra, no worries.
yees booy
Paulio
Postby tsoob » Tue Aug 25, 2009 5:43 pm
arrived today thanks so much bro.
Nick
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
tsoob
