cat007 wrote:I'm needing someone to design me a template and/or 3D drawing to get my caliper adapters made.
I can supply the hub, rotor and caliper with pads.
Anyone on here that way inclined?
Bazda wrote:cat007 wrote:I'm needing someone to design me a template and/or 3D drawing to get my caliper adapters made.
You can take it to Precision engineering and he will do it all for you.
How much it costs... not sure.
I usually make a mock up out of MDF. Then draw it up in CAD and get it laser cut.
If you make the mock up from MDF or what you need, I can draw it up in CAD and get it cut for you.
Bazda wrote:Depends how thick that plate is. And how long it is.
I would initially get them water cut, then take to a machinist to finish it off.
cat007 wrote:Bazda wrote:Depends how thick that plate is. And how long it is.
Well the thinnest piece could be anything up to +15mm....then the 'step' where the caliper would bolt up to would be another 6-7mm on top of that.
Bazda wrote:
1 flat piece 15mm water cut. Then get spacers made. Would work out really cheap.
I would think the plates would cost $50 each, the spacers would be cheap as like $40 to be lathed up.
For 15mm I would learn towards steel not aluminium.
sergei wrote:Also make sure bolts are up to it (ie have same strength as OEM or better).
Bazda wrote:I'm not sure how thick you would need to go... but mine are 20mm thick at the thinnest point and 35mm at the widest. Also with a huge radius on all edges.
From your pics... doesnt tell us anything about how to make the adapter plate really lol
cat007 wrote:Bazda wrote:I'm not sure how thick you would need to go... but mine are 20mm thick at the thinnest point and 35mm at the widest. Also with a huge radius on all edges.
Nah I know - I haven't taken any decent pics yet. Just wanted some of the caliper and rotor in place
I'll take some decent ones tonight
Are yours aluminium Barry?
