2jzgte altezza
2jzgte altezza
Am wanting a 2jzgte and r154 box to do this conversion so anyone with anything of help or any info let me know.
- tsoob
- Toyspeed Member
- Contact:
cool!!!!!!!
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
WHEELS, TYRES & SUSPENSION!
www.platinumwheels.co.nz
15 Parkway Drive
Mairangi Bay
09 486 5317
What kind of altezza do you have? Easiest conversion Ive seen is in a AS300 Gita, as they came factory 2JZ, but could probably swap the JZ mounts over to an RS200.
1999 SXE10 Altezza RS200Z
2004 Honda SCV100
Steam/Origin ID: nzEP85
2004 Honda SCV100
- evil_si
- Toyspeed Member
- Contact:
the gita mounts fit so engine will bolt in,
the cross members are different,
not sure if the gita c/m will bolt in, there were none available when we did the conversion, so i modified the stock member
a rear sump may be different and clear ok, we used a front sump
dont know about r154 as we used remote w58 and just made a mount to suit, had to fit captive nuts into chassis thou, the holes were there but 'blank'
- evil_si
- Toyspeed Member
- Contact:
adam had lots of issues with the wiring,
one of the biggest issues was the wanker the did a lot of it, basically he didnt know what he was doing and took a lot of shortcuts that cost us big. mite be why he now works at harvey normam
its running a link to control the engine,
the stock computer talks to the dash so that also has to be retained, (we found out after we had sold it with engine and loom) and the correct computer must be used or the dash wont work
the tacho and fuel guages are giving him issues
we have a supra diff waiting for the day the standard diff fails,
not sure with the vvti engine, the one we have is non vvti,
from my understanding the new link ecus will control it no problems
djb219 wrote:ok cool. OK if anyone knows what would be an average price to pay for a r154 box inc everything for manual conversion, ie pedals cylinders etc?
a remote shift R154 box with manual conversion bits......... dont expect change from $3K probably closer to 3.5K
Alehandro wrote:usually 1500-2000
hmmm not in new zealand. however i know ewan can import r154 boxes for quite cheap.
i paid 3k for mine. box with a new puck clutch start motor flywheel etc.
Your local Hybrid Elite tech
