Mr Revhead wrote:easy once you remove that bracket![]()
once you have that stud replaced as a bolt, there's no more problem
Bazda wrote:Replaced many times now without removing the cross members.
Just have to have the right set of tools.
Ideally you need the really really small socket sets to get to the bolts above the x member.
Roy wrote:hmm. ae101s are a little different, the bolts on the brace are right in from of the cross member- thus need to either
- lift the engine
- lower the engine (kinda impossible with the cross member there)
- remove the cross member
methinks I'll have a crack at removing the crossmember.. other (rangi) alternative is to jack the engine up after loosing off the front and back engine mounts... but would stress the side mounts on the engine...
any chance of being able to watch you break yours first neo?
sergei wrote:I usually knock out studs out rear mount when removing it. They are just pressed in and once they are out the rear mount will slide out easily.
