rear control arm bolt removal
Postby gleem » Sun Oct 04, 2009 11:32 am
On my camry, pretty sure other toyota aswell. the two rear arms that go onto the rear support axel has what looks like one long bolt going through it with one are in either side if the hub, i have taken the nut of and got one arm of but i can hardly get the other bolt to move and there fore cant get the other arm out. And ig tried hitting it with a hammer on the other end, Does anybody know or has it just sealed over time?
gleem
Postby fangsport » Sun Oct 04, 2009 3:01 pm
quite likely siezed in there.
can you turn the bolt ?
fangsport
Postby KinLoud » Sun Oct 04, 2009 8:20 pm
They tend to get a tiny bit of rust inside and so the bolt won't come out!
Curse a lot!
Heat (if you can arrange it)
CRC
be very careful bashing the end of the bolt at you can distort the thread and the nut won't fit on again!
No easy way sorry
ken
Postby gleem » Mon Oct 05, 2009 7:58 pm
ok thats all i want to know and yes has a bit of rust on the 4 part were the bolt goes through the hub, heat i presume you mean a torch of some sort, would a heat gun do it
gleem
Postby fangsport » Mon Oct 05, 2009 8:21 pm
i have had some success with CRC(or similar) and a good paint stripping heat-gun. heat it up whilst leaning on a power-bar.
fangsport
Postby sergei » Tue Oct 06, 2009 11:08 am
There is CRC product called Penetr8, it works better than run of the mill CRC.
Postby gleem » Tue Oct 06, 2009 3:32 pm
unfortunatly that bolt is now rounded to hiyying it out or getting a nut splitter in is the only option now
gleem
Postby jakesae101 » Tue Oct 06, 2009 4:47 pm
just remember if it doesnt work get a bigger hammer
EX. MK2 escort 4 door 1300cc
EX. AE101 trueno gt apex
jakesae101
