Good Year GSD3 vs Bridgestone Potenza RE001 Adrenalin
Postby sergei » Tue Oct 20, 2009 8:48 am
tsoob wrote:
classique71 wrote:ill be most likely going the re001's in the next month .. goodyears are DEAD .. killed them in 25K approx ith no heavy driving .. never again goodyear ...
How often did you check your pressures?
And what size tyre, what pressure did you run?
How many rotations in that time?
25k is low, but i would guess that you didn't take the best care of them to be so low
I can confirm that last set of GSD3 lost grip at ~30k (that was about 3mm of thread left), I run mine at 275kpa (yes I know that is highish but that is the pressure where fuel economy, grip, and steering response balance). I rotate wheels every service (5k), and usually I can wear out them very evenly (I also do wheel alignment every tyre change). The lost grip issue it seems because that compound got a lot harder, and stop being "sticky". This did not happen on German GSD3s, I could get out over 40ks on them.
Postby tsoob » Tue Oct 20, 2009 10:56 pm
I set all tyres 45 profile and below at 40 psi, and even a little higher once you get to 35 profile (44psi), so i'd say you are running them pretty much at the perfect pressure.
To me 25k's is low and there must be a reason for it.
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
WHEELS, TYRES & SUSPENSION!
www.platinumwheels.co.nz
tsoob
