Hilux 3l Diesel Engine - Crack prone?
Postby no_8wire » Thu Nov 05, 2009 9:21 am
I know that the 2.4 TD (2L) engines in the hiluxs/surf are pretty bad for cracking heads etc, however what are the 2.8 TD (3L) like in this regard?
Looking at buying an old surf and trying to decide between one with a 3.5L V8 (4V) or a 2.8 TD (3L)...
So any horror stories on the 3L since its in the same family of motors as the horrible gutless 2L?
no_8wire
Postby Mr Revhead » Thu Nov 05, 2009 9:31 am
the 3L is much much better
can still crack the head if the coolant system not looked after
4v is an interesting one....
Postby no_8wire » Thu Nov 05, 2009 9:50 am
yeah you dont hear much of the 4v... I cant seem to find any output figures for it though, but expect it to be pretty gutless since it is such an old model of motor..i.e 1973 carby...
Other than making sure the coolent system is ok and not leeting it overheat though, the 3l is a strong motor?
no_8wire
Postby YeMs » Thu Nov 05, 2009 5:07 pm
no_8wire wrote:yeah you dont hear much of the 4v... I cant seem to find any output figures for it though, but expect it to be pretty gutless since it is such an old model of motor..i.e 1973 carby...
yeh mate they are a hearty motor if they are looked after. their main problem is they suffer from lack of maintenance. the cooling systems corode/block up and cause them to over heat and crack heads. the majority of the time its from sitting under the seat of a van were there is limited air flow. they have a bad rep for blowing up, but the blame should be placed on the owners.
the 3L + Turbo combinations go extremely well. iv been involved in a couple of builds and they go really well, just gotta dyno them and pump them up with fuel to go with the boost and have a good clean radiator with fresh antifreeze.
Your local Hybrid Elite tech
YeMs
Postby d1 mule » Thu Nov 05, 2009 10:49 pm
iv got a hiace with 483kms on it (was courier van) and ita absoloutely mint to drive always starts mint etc way quicker/torquier than my old 2L-t hilux, tows my drift car easy as. WAY better motor than the 2L
d1 mule
Postby no_8wire » Fri Nov 06, 2009 7:55 am
YeMs wrote:the 3L + Turbo combinations go extremely well. iv been involved in a couple of builds and they go really well, just gotta dyno them and pump them up with fuel to go with the boost and have a good clean radiator with fresh antifreeze.
So did they not come factory with a turbo? Or was the reference to dyno and fueling only if you are increasing the boost?
no_8wire
Postby YeMs » Fri Nov 06, 2009 12:29 pm
AFAIK they only came NA. could be wrong and i wont put my name against it, but iv never seen a factory 3LT.
YeMs
Postby Mr Revhead » Fri Nov 06, 2009 12:36 pm
no, the 3l was never factory turbo
