Blacktop 20V Oil Seeping from Rocker Cover?
Postby Kittah » Fri Nov 20, 2009 2:38 pm
I seem to have oil seeping from between the engine rocker cover and head. Any ideas on what could be causing this? It doesn't piss out at all, but I can see that oil's been seeping from there.
Rocker cover gasket?
Kittah
Postby B_giB » Fri Nov 20, 2009 2:45 pm
Yes, Rocker cover gasket, Easy fix...
Current: SXE10 Altezza
AE101 Levin 20V super strut
1994 Mercedes Benz C280 Sport
B_giB
Postby Kittah » Fri Nov 20, 2009 2:53 pm
Simple job of unbolting the rocker cover, removing the gasket, replacing the gasket and bolting the rocker cover back on I take it? Nothing complicated or fancy involved?
Cheers for the swift reply by the way :)
Kittah
Postby xsspeed » Fri Nov 20, 2009 2:58 pm
is there a true gasket or just gasket goo?
will also need to prep the surfaces a bit to get rid if oil and other residue
Postby B_giB » Fri Nov 20, 2009 3:31 pm
Im 90% sure they are a rubber seal
B_giB
Postby xsspeed » Fri Nov 20, 2009 3:34 pm
ah toyodiy.com ftw
you are right there is a gasket there
Postby B_giB » Fri Nov 20, 2009 3:38 pm
I will change my certainty to 100% :lol:
B_giB
Postby Kittah » Fri Nov 20, 2009 3:56 pm
So it's a matter of removing the cover, clearing the old gasket and replacing it and then replacing the cover?
Much appreciated :)
Kittah
Postby Burning Angel » Fri Nov 20, 2009 4:49 pm
youll also need a few dabs of silicon around the humps in the gasket, you should remove the old stuff first.
1984 SRP61 Starlet
1999 WRX Type RA
Burning Angel
Postby AceSniper » Fri Nov 20, 2009 6:08 pm
3x 12mm nuts in the sparkplug channel (don't over tighten can crack cover)
2 x hex screws in the top cambelt cover
ohh and you need to unplug the a/c, oil pressure and vvt solenoid to lift the loom off the cover
AceSniper
Postby 85AW20v » Fri Nov 20, 2009 10:25 pm
Or you might find it just needs a bit of a tweak on the 12mm nuts.....
See ya
Simon
85 MR2 20v
85AW20v
