GTT st215 twin pots on ae corolla hubs ;)
Postby XSVWGN » Fri Nov 27, 2009 6:25 pm
so i purchased some 280mm discs from GGNZ cross drilled and vented for my ae100 wagon. Went on the search for some calipers today and was at Head Auto Wreckers (Lower Hutt) for about an hour trying all sorts of different calipers
Turns out the st215 gtt bolt up directly ;) so now i have some huge brakes for not much cash. Just thought i would share that with everone
brakes on the right are standard corolla brakes 240mm discs
Matt
2008 Kia rio - work car
XSVWGN
Postby 85AW20v » Fri Nov 27, 2009 10:13 pm
And are they 4 x 100 as well?
See ya
Simon
85 MR2 20v
85AW20v
Postby strx7 » Fri Nov 27, 2009 10:18 pm
all he did was bolt ST215 GT-T calipers onto his factory hub carrier.
ST205 4 pots bolt straight onto them aswell........
Postby 85AW20v » Fri Nov 27, 2009 10:29 pm
I was thinking about the disks more than the calipers seeing as they're four stud. Wondering if it would all bolt up to my AW as well.....
See ya
Simon
85 MR2 20v
85AW20v
Postby XSVWGN » Fri Nov 27, 2009 10:30 pm
discs are 4x100 275mm diametre to be precise
XSVWGN
Postby AE82 FXGT » Sat Nov 28, 2009 2:24 am
strx7 wrote:all he did was bolt ST215 GT-T calipers onto his factory hub carrier.
st205 calipers and rotors are a straight swap onto ae hubs?
Does that go for superstrut twin pots?
AE82 FXGT
Postby XSVWGN » Sat Nov 28, 2009 2:26 am
no as the st205 are 5stud and AE series are 4 stud. I bolted the st215 twin pots onto the AE hub
Matt
XSVWGN
Postby strx7 » Sat Nov 28, 2009 8:32 am
Why do people add things to the equations when you say a certain thing is do-able?????????
an ST205 4 pot caliper, can be bolted directly to an AE front hub carrier.
I never said anything about the disc. From my measurement you could run a disc of appox 290mm with this configuration if you could find a disc of the right measurements
Users browsing this forum: Bing [Bot] and 12 guests
