is 75-76mm I/D pipe easy to get?
Postby RomanV » Wed Dec 02, 2009 6:16 pm
I need some pipe, aluminium or stainless I guess, that's 75-76mm inside diameter.
3" aluminium pipe = 3" OD unfortunately...
So what's the next closest size up, that's available? Is there 3 1/4"?
It's for an airflow meter housing, so needs to be just right.
Postby ee904age » Wed Dec 02, 2009 6:41 pm
Seems not. By rights, tube is measured by outside and pipe inside. The closest I can find is Sched 40 S/S pipe in 3" which gives you an inside measurement of 77.92, but a hefty 5.49mm wall thickness.
90 SW20 Turbo - Project
90 SW20 N/A - Sold
ee904age
Postby 85AW20v » Wed Dec 02, 2009 9:03 pm
You could try high pressure PVC unless its for a turbo application of course as then the heat would probably be too much unless you had a very good intercooler.
See ya
Simon
85 MR2 20v
85AW20v
Postby no_8wire » Thu Dec 03, 2009 10:42 am
How long a piece do you need? I will have a kick around in the offcut bin see if I can find anything that suits...
no_8wire
Postby RomanV » Thu Dec 03, 2009 12:12 pm
Not too long!
150-200mm should do it... Maybe shorter if you had a short piece kicking around!
Postby fivebob » Thu Dec 03, 2009 12:39 pm
You should be able to get 3.5" with 0.25" wall thickness. If the outside diameter is too big just get it turned down.
Other alternative mignt be to get some 3" thin walled tube and expand it, though it might be a bit difficult to expand a piece that long :?
Postby Jebus » Thu Dec 03, 2009 2:04 pm
Try steel downpipes cuzz
Jebus
Postby no_8wire » Thu Dec 03, 2009 2:12 pm
RomanV wrote:Not too long!
Sweet will have alook tonight and see what I can find.
no_8wire
Postby Bling » Thu Dec 03, 2009 6:00 pm
How thick does it need to be? I have some thin 1-1.5mm(ish) alu pipe at work I can measure if thats not too thin.
Postby MAGN1T » Thu Dec 03, 2009 6:38 pm
Just roll up a flat piece and weld it.
Steve
Computers make you go mad.
MAGN1T
!USER HAS BEEN BANNED!
Postby Bling » Sat Dec 05, 2009 3:24 pm
Any luck?
I had a measure up of some aluminum pipe we use at work on gas water heaters.
77mm internal
80mm external
These will not be EXACT as I only have a cheap plastic vernier caliper to measure with.
Flick me a PM if you want some anyways, probably forget to check back here. Cover postage and its yours.
Postby Phothog » Sat Dec 05, 2009 4:29 pm
How about some carbon fiber tube ...?
http://www.carbonfibretube.co.nz/index.php?pr=Carbon_Tube_Prices
in a 1.2mm wall
75mm id 77.4mm od $ 87.14 p/mtr 0.44kg
76mm id 78.4mm od $ 88.28 p/mtr 0.45kg
if it is only for the Afm it would be ideal.
and they are in the back of beachhaven as well.
Chris.
1999 ST215W GT-T 325,000kms still going strong.
2000 M201G YRV Turbo, 1300cc little pocket rocket.
Need a Turbo Rebuilt or Upgraded... send me a email Chris @ Turbo.co.nz
Phothog
Postby RomanV » Sun Dec 06, 2009 4:22 am
Thanks for the advice people.
I may have a solution involving a factory airflow meter housing.
If it doesnt work out, will investigate some of these other options.
