Import All Stars - Finally 10's :)
Postby audi man » Wed Dec 09, 2009 8:33 am
loceda wrote:what did you have done to the C4 to make it handle the jandal??
Its not a c4 its the same as mine a th400.
1.5 jz mk3 supra,675rwkws at 28psi and 723rwkws at 32psi
audi man
Postby MAGN1T » Wed Dec 09, 2009 10:32 am
It's good to finally see some jappers doing something a bit different and using decent gearboxes. Very impressed with the video.
What rear end gears are you running?
Steve
Computers make you go mad.
MAGN1T
!USER HAS BEEN BANNED!
Postby holden_fan2005 » Wed Dec 09, 2009 12:16 pm
MAGN1T wrote:It's good to finally see some jappers doing something a bit different and using decent gearboxes. Very impressed with the video.
Steve
Agreed.
Throw a 9" in it and you'll be bullet proof :)
holden_fan2005
Postby audi man » Wed Dec 09, 2009 12:33 pm
Steve
At the moment we are running 3.7 stock lsd, but i think i am starting to have a problem with mine with the clutches starting to slip that why i was getting slower of the line last sunday,
audi man
Postby Bazda » Thu Dec 10, 2009 10:47 am
It looks too easy with that gearbox.
Just sit and enjoy the ride 8)
Postby Py7h0n » Thu Dec 10, 2009 12:46 pm
Yeah not really - Staging the starting and shifting are significantly more tricky than you would think.
Yeah we are still running the stock LSD which I think is nearing the end of it's life. Got a couple of plans to try and beef it up or will be looking at fitting a bigger rear end in there.
Py7h0n
