Clutch Master: New or Rebuild
Postby MrOizo » Sun Dec 20, 2009 11:18 pm
I have got to the point where the clutch pedal ends up on the floor and i need to keep pumping it to get it to work properly - not losing fluid so it has to be the master cylinder.
Where can the seal kits be bought? TGP, Repco etc etc, and if so, how much are they about?
Or would i be better off getting a new one? And again, how much are these? :)
Cheers.
MrOizo
Toyspeed Legend
Postby Silent Knight » Sun Dec 20, 2009 11:28 pm
Get a new one... I bought a new one for mine ages ago and it wasn't that expensive from memory. Probably around $70 back then IIRC.
Silent Knight
Postby MrOizo » Sun Dec 20, 2009 11:31 pm
oh sweet as.
Will do some asking around then :)
Now does anyone know it the volumes of the master clutch cylinders of the JZA80 and MA70?
MrOizo
Toyspeed Legend
Postby Akane » Mon Dec 21, 2009 1:03 am
Got quoted $310 genuine toyota, mine just feels very indirect. Not losing fluid.
Postby pc » Mon Dec 21, 2009 8:32 am
I'd get a pick-a-part one if possible because a clutch master doesn't have to mint, it just has to work.
red car
1/4 mile - 14.683s @ 91.83mph
Manfield - 1:24s
pc
Postby Nuty|Mike » Mon Dec 21, 2009 9:09 pm
Dude ill check it out with my contacts tomoro surely i can get one cheap new for you
05 Mazda Verisa .....for the Family
Nuty|Mike
Postby Py7h0n » Mon Dec 21, 2009 10:32 pm
Just get a new one - but make sure you do master and slave together (when one goes the other is not far behind)!
Py7h0n
Postby MrOizo » Mon Dec 21, 2009 11:38 pm
Nuty|Mike wrote:Dude ill check it out with my contacts tomoro surely i can get one cheap new for you
Farkin aye Nuty - would be the wickeds! I got not much work on for the rest of the week so can pick up befroe christmas if possibles :)
Would rather get new and not rebuild.
I should get a slave but will worry about that later - its relatively newer compared to the master as it came with the low km engine/box combo. Know thats not the best thing to do but all good for now :P
MrOizo
Toyspeed Legend
