qns relating to component speakers and amps
Postby escortman » Wed Dec 23, 2009 7:00 am
got some fusion componnet speakers and was wondering if i can run these through my amp or do they have to go off the head unit?
4x4 toyota blizzard offroader
escortman
Postby B1NZ » Wed Dec 23, 2009 8:25 am
I suppose it depends on the Amp and what output it has but generally speaking yes, you can run components through an amp and they usually are run this way as you generally get better sound as headunits have a basic sound output/level.
Subaru GF8 Wagon
Subaru GC8 rally car project
B1NZ
Postby AE82 FXGT » Wed Dec 23, 2009 12:15 pm
yeah depends on the gear, I run my components off an amp and thats all i have in my car sound wise, but everyone in impressed when they hear it.
AE82 FXGT
Postby Emperor » Wed Dec 23, 2009 12:21 pm
Yeh, aslong as it's not a big power monoblock haha.
My Fusions(lomus) are run through a DLS CA23(230rms 2 channel), good power and mental bass as well for little speakers
Emperor
Postby Crampy » Wed Dec 23, 2009 12:47 pm
Do it.
I never run any speakers off the headunit. Amps are way better.
I can turn the internal amp off on my headunit too, so it doesn't heat it up too much, good little feature
Crampy
Postby AE82 FXGT » Wed Dec 23, 2009 5:48 pm
Emperor wrote:Yeh, aslong as it's not a big power monoblock haha.
fancy gear, the sound coming from that would be mean :twisted: .
I set mine up on a budget with an fp402 powerplant amp and some kevlar jaycar response components.
I turn my internal amp off too, head unit amps are useless.
AE82 FXGT
Postby escortman » Wed Dec 23, 2009 6:49 pm
o ok mint will change to amp feed then cheers guys
escortman
Postby Crampy » Wed Dec 23, 2009 9:06 pm
AE82 FXGT wrote:I turn my internal amp off too, head unit amps are useless.
They sure are. They'll usually be clipping before the preout voltage is at it's max.
So, I turn off the internal amp, run the volume higher than normal and leave the gain on the external amp nice and low.
Goes mint.
Crampy
Postby AE82 FXGT » Wed Dec 23, 2009 9:40 pm
Goes mint.
haha, thats what I do too, only put the gain on the external amp about 1 or 1.5volts below the head unit pre out voltage.
AE82 FXGT
