Mike228 wrote:Limits on power ratings are silly for a few reasons.
First of all pretty much anything you buy these days is fast enough to kill you if you drive it into a power pole.
Third, it is more about the kind of driver, someone who's going to wipe themselves out in a rex is just as likely to do the same in a corolla.
Hmmm.... I don't think you understand the.... 'Side effects' of having more power.
If someone is used to driving a Corolla, and they jump into a WRX, they're not going to be used to the power difference.
Its the same with handling. Cars that can go right to the edge of handling are double edged swords. Unskilled people will be more likely to crash then. Hell, don't believe me? Go look on the net for all the crashed Enzo's out there!
So someone who wipes themselves out in a WRX is a lot LESS likely to do so. Sure, it may be able to go just as fast as it will probably ever be driven on the roads, but the rate at which is gets there, and the speed it can carry through the corners is a different story
