ST202 manual gearbox filling...
Postby peas » Sat Apr 10, 2010 5:16 pm
Hello all.
I have noticed that my girlfriends Celica seems to sound "dry" from the box and its shifting isn't what I would call smooth. Anyway I undid the 24mm bung on the front of it and poked in a curled over piece of metal and didn't manage to get it into any oil (none on it when I pulled my make believe dipstick back out anyway) so I'm assuming that it is dry or close to it and is it correct to fill it until it comes level with the filling bung... as in just starts seeping out?
Thanks guys.
'97 Caldina GT (ST215G)
peas
Postby Quint » Sat Apr 10, 2010 5:37 pm
Yeap, might as well drain it, then fill it back up till its at the bung.
Quint
Postby iOnic » Sat Apr 10, 2010 5:39 pm
Yup correct. I normally leave the filler open and fill it from the top (speedo sender/reverse sensor) until it starts to seep out the side.
Postby peas » Sat Apr 10, 2010 5:40 pm
Sweet cheers guys... will throw some oil in it tomorrow.
peas
Postby peas » Sun Apr 11, 2010 5:34 pm
How much ar they meant to take?!?!? It swallowed up a 1L bottle and a quarter of the 2nd one!!!
peas
Postby iOnic » Sun Apr 11, 2010 5:43 pm
Did you drain it? You aren't really supposed to mix old/new oil. They're just under 3 liters from memory.
Postby Bling » Sun Apr 11, 2010 6:46 pm
Yeah mixing could be a bad idea if that's what you did. Who knows what grade of oil is in there to start with as well.
Postby sergei » Sun Apr 11, 2010 8:03 pm
Mixing is bad especially in gearbox oil as they could use different chemistry in their friction additives for synchros that could react together.
Postby peas » Sun Apr 11, 2010 11:30 pm
Noted... thanks guys will drain and sort it out with totally new oil.
peas
