4age 20v silvertop headblot problem
Postby KIPH8N » Sun Apr 25, 2010 11:52 pm
I have a 4age 20v silvertop i was taking out the head but i have fully made the top part of the head bolt thing round because there were carbon deposit underneath and a put the spanner in and rotated it with a power bar but now the head bolt is fully round and when i put the socket in and try to take it off the socket rotates by itself. Any idea how i could take it off? :(
KIPH8N
Postby Bling » Mon Apr 26, 2010 12:12 am
One solution is to weld a bolt on top of it. If no welder though, not sure :( Someone else would have had this problem so will post up :)
Postby dusk93 » Mon Apr 26, 2010 12:20 am
I had the same problem and as it was the last one left and I had a new set of headbolts, took a drill to the head of the bolt so I could lift the head off, then undid the rest of the bolt with vice grips :)
Not that it was that tight after drilling the head off 8O
Hope this helps,
Johnathan
Current: 1983 AA60 Coupe, 1987 E30 318i coupe, 1985 SA70 Parts Heap, 1990 R32 GTST Coupe
Ex: 1982 AA60 Coupe, 1987 AE92 FXGT (RIP), 1989 Mazda Astina BG hatch, 1994 R33 Skyline GT ( RB20E powered :( )
dusk93
Postby frost » Mon Apr 26, 2010 2:32 am
dusk93 wrote:I had the same problem and as it was the last one left and I had a new set of headbolts, took a drill to the head of the bolt so I could lift the head off, then undid the rest of the bolt with vice grips :)
Hope this helps,
Johnathan
i found this to be the best way,
best to do it on a steady drill press, at least then you wont slip and drill a hole in your head,
