matt dunn wrote:you would probably be better off with a Blacktop flywheel or an aftermarket one rather than lightening your one.
Matt
CAMB01 wrote:A standard smallport has 10.3:1 compresion, so i hope the pistons you are planning on getting are going to better than that?
Shave the head and get a TRD metal headgasket. Compression ratio plays a big part to what cams you want to run.
Maybe a port job on the head. New valve guides makes a difference as well if the old ones are worn.
3+ angle seat job, maybe back cut the inlet valves as well. Port match the inlet manifold.
Lightweight flywheel, balance the rotating assembly including rods and pistons.
Kittah wrote:B_giB wrote:You shouldn't need a cert for a 20V.
Pretty sure the extra power output would make certification necessary. You may get away with it, though.
Malcolm wrote:btw a cert is more like $400
