4agze problems.. again
Postby z|gen » Sat Jun 26, 2010 1:33 pm
Hey guys..
finally got my car a warrant.. :D
but, its still having issues..
engine is a 4agze from ae92 with AFM, and has CAS and coil packs..
problem is the car dies at low rpm when warm, when engine is cold, its fine, and it runs fine over 3000rpm, but anything under and it sucks..
i took it to my mechanic (midas porirua) and they spent 3 days going over it and couldnt find anything and said that its likely to need an aftermarket ecu and an auto sparky..
before i go down that route, has anybody got any ideas?
was thinking of changing to distributor and single coil set up?
dave
AE91 SUPERCHARGED COROLLA
z|gen
Postby Quirky » Sat Jun 26, 2010 4:11 pm
You checked the codes?
Might want to try checking the AFM, might be buggered.
Hello There
Quirky
Postby z|gen » Sat Jun 26, 2010 4:16 pm
Hi,
Havent checked codes yet, waiting for the rain to stop.. does the car need to be running to check them?
Dave
z|gen
Postby Quirky » Sat Jun 26, 2010 5:34 pm
Just get a paper clip, and put in the diagnostics box.
Terminals E1 and T.
Turn the key to ON, but dont start. And count the engine light flash, make sure to note the intervals between them.
Hello There
Quirky
Postby z|gen » Sun Jun 27, 2010 11:27 am
hey,
just tried that, CEL just blinks normally, so its not showing any fault codes?
Dave
z|gen
Postby gepsk8 » Mon Jun 28, 2010 10:52 am
had the same problem, it dx corolla with ze once so put map ECU & loom fix all problems as car was wired dodgy with afm ecu.
it wasnt afm or ecu
O272754663
gepsk8
Postby z|gen » Mon Jun 28, 2010 11:16 pm
yeah, went back to midas today to clarify a few things..
its not ignition related, so its fuel.. they think either ecu, afm, oxy sensor or TPS..
so just trying to find another early model ae92 gtz afm and ecu to try and i think il just see if i can get brand new oxy sensor..
not alot of these engines around and i dont know anyone in welly with one either to try test and eliminate bits either
z|gen
Postby gepsk8 » Tue Jun 29, 2010 10:45 am
i should have old ecu u can try, will look for you next time im in welly
o2 Sensor just unplug it, should effect it that much, will run will out it no problems
O272754663
gepsk8
Postby z|gen » Sun Jul 04, 2010 12:06 am
bump..
possibly thinking may be linked to a vacuum line issue through the VSV..
while having a look at all the vacuum hoses.. for replacing the boost guage and to do the abv mod, mine seems different..
iv drawn a rough picture of how mine is setup at the moment, any ideas on correcting it?
thanks Dave
z|gen
Postby CXGPWR » Sun Jul 04, 2010 8:46 pm
Remove the fire trucking IDLE CONTROL VALVE - DO A GOOGLE SEARCH, DOWNLOAD 4AGZE MANUAL AND READ IT, FIND OUT WHERE THE IDLE CONTROL VALVE IS AND REMOVE IT, CLEAN IT TILL YOU CAN SEE YOUR REFLECTION. REFIT & YOU'LL BE AWAY LAUGHING
Done
CXGPWR
CXGPWR
Postby CXGPWR » Sun Jul 04, 2010 8:47 pm
CXGPWR
Postby z|gen » Mon Jul 05, 2010 12:13 am
CXGPWR wrote:Remove the fire trucking IDLE CONTROL VALVE - DO A GOOGLE SEARCH, DOWNLOAD 4AGZE MANUAL AND READ IT, FIND OUT WHERE THE IDLE CONTROL VALVE IS AND REMOVE IT, CLEAN IT TILL YOU CAN SEE YOUR REFLECTION. REFIT & YOU'LL BE AWAY LAUGHING
Done
CXGPWR
no need to yell mate, sorry im not as clued up as you are.
z|gen
Postby try_hard » Tue Jul 13, 2010 5:18 am
What is the idle like up to 3000. Is it ruff like it is missing?
Just as my bike dose this only when warm (i dont know why not when its cold). my problem is i have 600cc carbys (with aftermarket needels) on my 400cc engine. but i am still getting to much fuel, only affects it when its warm and below around 2000-1500 rpm. I'd check sensors that control fuel as it sounds very similar. I live with it as it works to my advantage.
O2 sensor maby idk. but i'd be testing any that could effect fuel flow and amounts. and even the fuel punp (pump mainly wont flow enough when they start to go, so it effects high revs not low ones) but worth a look
AE92 Trueno Sprinter 4AGZE
try_hard
