having fun finding a hole!!
Postby GT101 » Sat Jul 03, 2010 7:12 pm
Hole to run my amp power cable through the fire wall that is :lol:
anyone found an easy spot to run it through on an ae101 corolla/sprinter?
usually find one of those rubber bungs etc to feed it in , but havent been able to find a suitable one as of yet the i can reach with ease.
my son needed attention so i left it and though i should ask on here first befoe trying again .
once again any ideas would be awesome.
current :project cynos version 2
previous toyotas :93 ae101 sprinter gt sedan 20v, 93 gt starlet,el44 cynos alpha,ae101 trueno.....
GT101
Postby Bling » Sat Jul 03, 2010 7:51 pm
When I had sounds in my Levin I ran it through the passengers side guard, above the stone cover and in through the firewall with some other wires. Could be worth taking the covers out of the guard and seeing if there's an easy way through.
Postby matt dunn » Sat Jul 03, 2010 8:00 pm
Yeah, probably going to be a mission to go thru the firewall.
Better to follow the existing loom and go out through the inner guard.
Postby DeeCee » Sat Jul 03, 2010 8:20 pm
you should be able to go through the standard engine wiring loom bung, down behind the fan unit :)
GT Four Adovansu
DeeCee
Postby Stott69 » Sat Jul 03, 2010 8:34 pm
Or go to repco and buy some bungs and make your own hole
Image jzs147 Aristo money pit
Stott69
Postby GT101 » Sat Jul 03, 2010 8:52 pm
Stott69 wrote:Or go to repco and buy some bungs and make your own hole
the thought crossed my mind heheh
i found the one that goes through the passengers side guard , there was another wire that was connected to the battery already going through that lead to nowhere.
i removed that so probably will take that stone guard off tomorrow and have a closer look.
will tidy up the random wiring that i found aswell and might removed the air purifier if i have time.
cheers for the info guys
GT101
Postby ch4ng » Tue Aug 10, 2010 12:31 am
The last time I did sounds in an ae101 I ran the power cable through the a/c bung
Chondah Civic
2T Navara
ex:
Charade Detomaso
MX5 - Stancemobile
MX5 turbo - El Tigre
87 Alto - The Tragic 3cyl powah
AE111 BZ-G Death Race 15.09
No Limits Onsite Paint Repairs. Cut and polishing, stone chip and scratch repairs. 021-177-8539 Mention Toyspeed.
ch4ng
Postby BZG Wagon » Tue Aug 10, 2010 8:26 pm
It was a long time ago now, but I ran mine through the A/C bung. From memory passanger side, towards the bottom. Real easy to get it through.
BZG Wagon
Postby sark.inc » Wed Sep 01, 2010 7:58 pm
ch4ng wrote:The last time I did sounds in an ae101 I ran the power cable through the a/c bung
do this, also do not run it under the outside guard as that can be a bit dodge.
sark.inc
Users browsing this forum: Google [Bot] and 0 guests
