I seem to remember quite a few sw20's running low 12's with just a bit of boost and a CT20b
dnalunchie wrote:I would tentatively suggest that an sw20 would be pretty easy to get down into the 10's or even 9's given its mid rear layout which should provide good grip off the line and the ability of the 3sgte engine ro make good power as long as its not connected to a caldina![]()
1I1 wrote:EDIT: found this: http://www.performancecar.co.nz/articles/import-drag-racing-records/import-drag-racing-records
But I'm sure there was a Red Gen3 with over 300rwkw that ran a 10 as well
Lith wrote:
LOL you make that sound like those are good times for the mods!! You can go fast for few mods if you are willing to play with fire, 30psi through a GT30 to run 12s in a AWD is a bit of a shocker imho![]()
Lith wrote:Umm, 28psi is no small amount stillI did 12s with a GT30 running 14psi in a car which is only RWD!
MR2s have epic potential, and of course there are things like the Croydens Supra etc which did 9s
Boost_4_Life wrote:1I1 wrote:EDIT: found this: http://www.performancecar.co.nz/articles/import-drag-racing-records/import-drag-racing-records
lol, from that list:
Jeffrey Richardson Spec Performance Toyota Starlet KP 10.40 @ 216kph (134mph)
thats one mean 4k
iOnic wrote:I don't think any (Toyota engine'd) 4cyl Toyota has gone faster than TIMID (4AGTE + T51R) and as for fastest Toyota 4wd.....I wouldn't expect much given the number of fairly modified Celicas doing the same times as near stock SW20's
rollaholic wrote:tube frame it and put the engine in the front, if rayglass can call their car a celica theres no reason you couldnt paint some pop ups on it and call it a mr2
or take some inspiration from crazy honda drag cars
