Failed WOF on Tyres - Really Annoyed
Postby BZG Wagon » Sun Aug 22, 2010 5:04 pm
Exactly two years & one month ago I bought a set of Eagle F1 gs-d3 tyres for a lot of money. They guy at the tyre shop reckoned I should get at least 45,000kms out of them on my GTT so long as they were looked after (regular alignments, tyre rotations etc), which I did.
Went for a WOF today and the front tyres failed, with the left tyre just starting to wear through to the canvas in patches. I'm infuriated given I've only done 25,000kms since purchase.
It this the result of the tyre or the alignments - I'm leaning towards alignments given the amount of treat over the rest of the tyre? What should I expect out of a set of tyres like these - 25,000kms seems ridiculously poor.
BZG Wagon
Postby wde_bdy » Sun Aug 22, 2010 5:09 pm
Depends on the roads your are on and how you drive it, with regular rotations, alignments etc I get max of 30,000 out of my 195/50 15's on a Mazda Demio. NZ has some pretty coarse roads that don't really help tyre wear, although my car gets driven pretty hard which wouldn't help the wear rate.
Callum
wde_bdy
Postby Emperor » Sun Aug 22, 2010 5:10 pm
Proxes4 lasted 10,000kms for me lol
T1Rs so far have almost done 10,000 and almost no wear.
Way you drive will change it, and maybe incorrect allignment.. But at the end of the day not much you can do about it, other than choose a new tire shop.
Emperor
Re: Failed WOF on Tyres - Really Annoyed
Postby Bling » Sun Aug 22, 2010 5:24 pm
BZG Wagon wrote:It this the result of the tyre or the alignments - I'm leaning towards alignments given the amount of treat over the rest of the tyre? What should I expect out of a set of tyres like these - 25,000kms seems ridiculously poor.
Photo of tyre? I would lean towards alignment probably.
When was the last alignment and how did you not notice it wearing that bad in patches? That would stand out like a sore thumb, doesn't matter what tyres you get if you don't check them over occasionally you won't notice uneven wear. I check my tyres (same as yours) every couple of months for tell tale signs they aren't wearing even. Not sure on KM's but i've had them probably 20-25k (guess) with 2/3 wear on front and 1/3 wear on rear.
Postby B1NZ » Sun Aug 22, 2010 5:35 pm
As others have said it all depends on how you drive it etc.... 25000kms could be about right for sticky tyres, Was it just the front tyres worn? Do you rotate and check regularly?
Our rep went through some version of toyo tyres in the work legacy in 20000km's
Subaru GF8 Wagon
Subaru GC8 rally car project
B1NZ
Postby BZG Wagon » Sun Aug 22, 2010 5:51 pm
The roads are probably an even mix of smooth & coarse chip.
Back tyres are 3mm. I check then every few months or so in between warrants. Haven't noticed any irregular wear.
Driving style; yes I do tend to corner quick fast on windy roads and motorway offramps; but like I said it's 80kph - 100kph open road kind of stuff most of the time. It's not like I can pull skids in the tyres either given I'm in a 4wd.
I've had two alignments so far (every 10,000kms as instructed) and was about to book in the third. I was told at my last alignement the tyres wouldn't need rotating for another 7,000kms - 10,000kms (which would be now).
I check the air pressure when the car is cold every month too - running 35psi in the front and 36psi in the back, as instructed (215/45/17's).
Pictures:
BZG Wagon
Postby wde_bdy » Sun Aug 22, 2010 6:11 pm
The problem you have is like may late model cars you get excess wear on the inside of the tyre even though the rest of the tread is wearing pretty flat if the car is driven hard. Those probably should have been flipped on the rims rather than rotated last time, otherwise you get all the wear concentrated on the inside edge when just swapping front to rear. Factory or lowered springs? Seems more common on factory cars.
Callum
wde_bdy
Postby Lloyd » Sun Aug 22, 2010 6:17 pm
Its a b*tch, but thats how they tend to wear even with alignment in spec. And its not just F1s, majority of tyres so and they wear like that on the front more than the rear
Postby Tofu » Sun Aug 22, 2010 6:22 pm
Thats eagles for you. they have no tread on the outsides unfortunately.
[WAAA] - 98' JZX100 Chaser Tourer V
Tofu
Postby Bling » Sun Aug 22, 2010 8:25 pm
My eagle, ~3mm of tread left (below), even wear, so it is possible, I don't think blaming the tyre is right if I can get even wear. I run 36-40psi in mine. I know sweet f**k all about about alignments, but that to me looks like turning on the spot, or toe in? If that's where the tyres a pointed slightly inwards? Dunno, just working out how it would scrub the edge like that. Compared to mine, i'd say its been wearing the edge for quite a while.
My old work hiace van used to do it ~95 model, both insides would wear faster. Current ~2000 hiace doesn't have the problem.
Is it worn exactly the same both sides? If the otherside is fine that makes me believe even more so the alignment might be at fault. Hit any decent pot holes?
Postby Helious » Sun Aug 22, 2010 8:50 pm
that sucks. heaps of tread, just that inner wall has been owned.
go see an alignment specialist
edit: good news is they're $179inc new now, pretty cheap.
Helious
Postby snwtoy » Sun Aug 22, 2010 8:55 pm
Tyres on my Caldina wear like that too, it's always the inside shoulder of the fronts.
Mine's lowered on Tiens, and correctly aligned. Anyone else with a Caldina find the same thing?
snwtoy
Postby dnalunchie » Sun Aug 22, 2010 9:15 pm
Interesting the type of tire, I have had SUPER fast wear on GSD3's as well. In my old Trueno and my ITR got from full to half tread in less than 3000kms
EX:89 RS and GT Legacys, 90 EF9 Civic, 95 Integra R, 95 AE101, 90 ST185, 88 Accord, 87 3rdoor and 5door Swift hatch, 91 Pontiac Lemans, 80 Liftback Celica, 95 Hornet 250
Current: 90 3sfe Corona
dnalunchie
Postby matt dunn » Sun Aug 22, 2010 9:20 pm
I bought an expensive set of tyres fro a road car once,
lasted less than 1/2 what the tyre guy told me they should last,
Now I use cheap shit new tyres,
as I dont drive the road car anywhere near the limit of the tyres anyway,
and they last as long or longer.
Postby dnalunchie » Sun Aug 22, 2010 9:51 pm
Oh I should have also mentioned that I am a crap driver... so that may account for excess wear
dnalunchie
Postby fangsport » Sun Aug 22, 2010 9:53 pm
matt dunn wrote:Now I use cheap shit new tyres,
yip, x2
i have the worlds worst wet weather tyre (well i hope it is anyway, any worse could be fatal) on the corolla and have to rotate F/L every 500-1000km, to even the wear rate as i had to do a tight u-turn on coarse chip each morning,and on simaler surface each nite.......... tyre wear might even up a bit, as i don't live there no more.
fangsport
Postby Mr Revhead » Sun Aug 22, 2010 9:55 pm
fangsport wrote:i had to do a tight u-turn on coarse chip each morning,and on simaler surface each nite.......... tyre wear might even up a bit, as i don't live there no more.
I used to live on Cragie ave, and had an Escort with a locked diff...
I found the hand brake left flat spots, and power flicks wore out the tyres fast :?
Postby Helious » Sun Aug 22, 2010 10:22 pm
Bridgestone Supercat tyres for the win ;)
Helious
Postby AE82 FXGT » Sun Aug 22, 2010 10:55 pm
Looks to me like it could be toe/negative camber related, you cant really blame wear patterns on the tyre.
AE82 FXGT
Postby fangsport » Sun Aug 22, 2010 11:22 pm
Helious wrote:Bridgestone Supercat tyres for the win ;)
mate,they are like oldschool A-008rs compared to the Goodride i have on the corolla!!
fangsport
