4age auto to manual conversion
Postby mikeymike » Sat Aug 28, 2010 2:15 pm
I've decided that the auto just needs to go from my smallport red top ae92 fx-gt. I've got a ae92 gtz lsd box to go in. Just wondering a few things:
1. Do I have to run a 4agze clutch set up with the box? (I've already got a 4agze flywheel)
2. Will the auto shafts fit or will I have to change something there too?
3. Pretty sure I'll need manual gearbox mounts, but just checking that the auto ones won't fit?
Cheers,
Mike
Current cars: Ae92 fx-gt
Previous cars: Suzuki escudo tuff truck, mx83 cressida, kp61 starlet
mikeymike
Postby Dell'Orto » Sat Aug 28, 2010 2:27 pm
Sell that box, and buy a C56. E51 ratios aren't really suited to a 4AGE
Postby Quirky » Sat Aug 28, 2010 2:48 pm
E51 gear ratios aren't that bad, its just the long 3rd gear you might struggle with.
Hello There
Quirky
Postby mikeymike » Sat Aug 28, 2010 2:59 pm
Just looked up the speeds vs. rpm online. E51 has longer ratios (100.88kph @ 3000rpm), C56 (89.92kph @ 3000rpm). It's only a daily driver so this shouldn't be too much off a biggy?
mikeymike
Postby KinLoud » Sat Aug 28, 2010 11:30 pm
Certainly you will need the correct driveshafts for the E series gearbox
You will need the correct mounts for the gearbox
You will need to use the correct clutch as the E series box has a bigger diameter input shaft
You will lose some power as there will be bigger losses through the gearbox
Also the gearbox weighs about 15 or 20kg more than the std C series manual gearbox
The ratios are way more suited to the extra mid/low end torque of the GZE engine
Ken
Postby 85AW20v » Sun Aug 29, 2010 12:02 am
Your car will be slower with the E than the C box. My AW was 3 seconds quicker around the old Taupo track with the C box than the E box - it was the only change I made between race meets. As Kinloud has said, it's the extra weight of the gearbox, the internal components and the driveshafts that do it. Although the E series flywheel and clutch are lighter, they won't fit inside the C series box.
See ya
Simon
85 MR2 20v
85AW20v
Postby mikeymike » Sun Aug 29, 2010 10:01 am
Thansk for that guys. Hmmm might have to sell it and look for a c56. Be cheaper and better in the long run.
mikeymike
Users browsing this forum: Google [Bot] and 26 guests
