Turbo oil drain issues ??
Postby AE86fan » Tue Aug 31, 2010 1:57 pm
My turbo has been smokey especially noticable when deccelerating. There is obvious oil in the exhaust housing which would indicate that the seals are stuffed.
I spoke with a guy from specialist Turbo shop and he said that it is probably an oil drain issue caused by either running my sump overfull or bore damage which was pressurising the sump......makes sense.
He also said that if if I resolve the above 2 issues the seals may not be damaged in any way and it may solve the problem without a rebuild.
I dont know enough about how the oil seals work in turbos to know if the problem might only be temporary, has anyboby had any similar experiences???
1984 NZ AE86
AE86fan
Postby Akane » Tue Aug 31, 2010 8:29 pm
The oil drain has to be gravity fed straight into the sump, no U shape joints (Like you find in a kitchen basin drainage).
I believe it is because when the oil coming out from the turbo is more like a foam / candyfloss type looking thing. Lots of air, pressure build up. There needs to be no pressure build up in the oil drain line, air or oil.
I have experienced this first hand with the GReddy TD06 i had, blown the oil seal.
Another workshop on the shore also did this without my approval on my other GT turbo, and it started smoking, luckily they didn't "test drive" my car very far, I reversed their "mod" and my turbo was a happy chappy again.
Postby AE86fan » Tue Aug 31, 2010 8:35 pm
Cool thanks, so the turbo might be salvageable. I will try running the oil level a little lower and maybe raise the level of the where the drain meets the sump.
Hopefully with less pressure in the sump with some new pistons and rebore, problem solved.
1984 NZ AE86
AE86fan
Re: Turbo oil drain issues ??
Postby QikStarlie » Tue Aug 31, 2010 9:40 pm
AE86fan wrote:My turbo has been smokey especially noticable when deccelerating.
how are your oil breathers setup? you could be pressurizing the crank case under boost. which will result in a cloud of smoke coming off boost.
do you have a restrictor in the feed?
no need to drop the oil level if setup right.
QikStarlie
Postby B_giB » Wed Sep 01, 2010 8:35 am
Akane wrote:The oil drain has to be gravity fed straight into the sump, no U shape joints (Like you find in a kitchen basin drainage).
That wasn't a certain shop that used to be on Sunnybrae road was it Akane?
Current: SXE10 Altezza
AE101 Levin 20V super strut
1994 Mercedes Benz C280 Sport
B_giB
Postby Akane » Wed Sep 01, 2010 4:32 pm
B_giB wrote:That wasn't a certain shop that used to be on Sunnybrae road was it Akane?
Why yes it is, got ripped off $600 and lesson learnt.
Postby B_giB » Wed Sep 01, 2010 4:41 pm
I remember seeing it there, When I was working for Tyre City
B_giB
Users browsing this forum: Google [Bot] and 28 guests
