GT4 gearbox in GTT Caldina??
Postby James Sen » Mon Sep 06, 2010 8:50 pm
A friend has a GTT caldina and the gearbox has craped out, Its hard to find another manuel gearbox for it and its expensive, so he was wondering if he could fit a gear box out of a ST185 gt4 celica, is there much difference between the to box's???
James Sen
Postby strx7 » Mon Sep 06, 2010 11:54 pm
GT4 box is internally stronger than the GTT boxes are, hence the GTT boxes are so hard to find and worth good $$$. You may need to use the axles or at least the inner CVs from the GT4 gearbox
Postby James Sen » Tue Sep 07, 2010 12:41 am
ok cool, so you reckon the gt4 box should bolt on to gtt..
James Sen
Postby strx7 » Tue Sep 07, 2010 8:01 am
yip cause i have a GT4 box bolted to a GTT engine in my corolla at the moment
Postby Mr Revhead » Tue Sep 07, 2010 11:46 am
strx7 wrote:yip cause i have a GT4 box bolted to a GTT engine in my corolla at the moment
if Dr Frankenstein built a car.....
Postby XS1V » Tue Sep 07, 2010 12:39 pm
And I have a gearbox if you need one 8)
Brad
ST205 Group A Rallye #2363
XS1V
Postby James Sen » Tue Sep 07, 2010 7:22 pm
LOL must be a wicked corolla, i'll let my friend know, and how much do you want for the gearbox brad...
James Sen
Postby RomanV » Tue Sep 07, 2010 7:37 pm
Wouldnt you need to make sure that the diff ratio in the GT4 box matches the rear differential in the Caldina?
Postby sergei » Tue Sep 07, 2010 7:48 pm
RomanV wrote:Wouldnt you need to make sure that the diff ratio in the GT4 box matches the rear differential in the Caldina?
I believe they are all the same.
Postby strx7 » Tue Sep 07, 2010 9:04 pm
James Sen wrote:LOL must be a wicked corolla, i'll let my friend know, and how much do you want for the gearbox brad...
viewtopic.php?t=54196&highlight=
Postby cedwards » Tue Sep 07, 2010 9:39 pm
have a gtt box that may be surplus to requirements, should know by end of the week.
Done just over 100000 ks
Pm me if you interested
cedwards
Postby cat007 » Tue Sep 07, 2010 10:26 pm
Sweet. Nothing ever goes wrong when you believe ;)
Postby sergei » Tue Sep 07, 2010 10:56 pm
Excuse me, but my "believe" is a bit substantiated unlike religious "believe".
When I say "believe" I mean is that I am certain to a degree but not 100%.
If you have facts proving otherwise, I "believe" they are same ratios.
Postby Lloyd » Tue Sep 07, 2010 11:02 pm
And if you haven't got facts to prove they are then many would "believe" that there are differences between models ;)
Postby sergei » Tue Sep 07, 2010 11:13 pm
Lloyd wrote:And if you haven't got facts to prove they are then many would "believe" that there are differences between models ;)
All GT4 share same rear diff ratio. That is based around my personal experience from matching different bits together.
here are the facts:
ST246:
http://www.toyodiy.com/parts/p_J_2003_T ... _4101.html
look at the part# 41201-80136 look at the FGR : 41:14
ST215 Auto:
http://www.toyodiy.com/parts/p_J_1999_T ... _4101.html
look at the part# 41201-80025 look at the FGR : 41:14
ST215 Manual and ST205:
http://www.toyodiy.com/parts/p_J_1998_T ... _4101.html
or
look at the part# 41201-80069 look at the FGR : 41:14
The ST215 manual shares same part number with ST205 for the FGR.
Now you made me do all this homework, when I don't even need to swap diffs.
Postby Lloyd » Tue Sep 07, 2010 11:43 pm
Better. Thank you Sergei :)
Users browsing this forum: Bing [Bot], Google [Bot] and 16 guests
