4age injector upgrade
Postby 88.4ageGT » Tue Sep 21, 2010 10:01 pm
I was wondering if there was a upgraded injectors for a 4age?
AE92 4age GTi
Building 3sge ae92 race car
Malcolm wrote:I didn't know they had maths on waiheke
88.4ageGT
Postby Dell'Orto » Tue Sep 21, 2010 10:07 pm
Yep
Postby touge_ae101 » Tue Sep 21, 2010 10:10 pm
for churbro application or jus' cause?
touge_ae101
Postby 88.4ageGT » Tue Sep 21, 2010 11:08 pm
What are they? coz was looking to upgrade the ones in my road car
AE92 4age GTi
88.4ageGT
Postby touge_ae101 » Tue Sep 21, 2010 11:44 pm
what are they in terms of??? i will assume you know what they do in terms of injecting fuel into the engine.
this is what they look like
obviously there are slight differences between each type of 4age - BT, ST, 16V and ze but i think you can find that info for yourself if you look.
if it is a road car it is not worth upgrading them as unless you have done a serious amount of modifying they won't be the thing that is holding your setup back from making more power. 4age injectors are quite big for their application.
to give you an idea of what kind of modifications you can get out of stock 4age injectors, read up on BZR4AGE's build thread. fully rebuilt engine with toda pistons etc, nasty amounts of compression, 304 cams and pushing out a healthy 135ish kws and not in need of upgraded injectors.
this is my take on the whole 4age injector topic. anyone else please feel free to add more/tell me if i'm wrong.
touge_ae101
Postby l1ttle_d3vil » Tue Sep 21, 2010 11:58 pm
You can put some 550cc RX7 Injectors in. They'll bolt straight in with no mods needed, and instantly give you about 50% more fuel. I run them in my road car, but I occasionally drag it too.
Postby blindnz » Wed Sep 22, 2010 12:03 am
20v injectors are 295cc or something which is a pretty decent size, the early 16v from memory are 185cc? Is it 16v or 20v and what mods?
blindnz
Postby touge_ae101 » Wed Sep 22, 2010 12:27 am
l1ttle_d3vil wrote:You can put some 550cc RX7 Injectors in. They'll bolt straight in with no mods needed, and instantly give you about 50% more fuel. I run them in my road car, but I occasionally drag it too.
lmao pretty serious road car albeit eh. :lol:
touge_ae101
Postby Adamal » Wed Sep 22, 2010 12:32 am
Use injectors relative to the power you're making. You won't get any benefit from larger ones if everything else is the same. In fact, it can leave you worse off, as larger injectors don't atomize the fuel as well when injecting lower volumes.
Postby matt dunn » Wed Sep 22, 2010 1:06 am
What ECU do you plan to use, as if you go to larger injectors you will need an aftermarket ECU.
Postby Akane » Wed Sep 22, 2010 4:02 am
matt dunn wrote:What ECU do you plan to use, as if you go to larger injectors you will need an aftermarket ECU.
What, you mean my S-AFC won't be "sweet as bro!"?
Postby tsoob » Wed Sep 22, 2010 3:50 pm
I have a set of 4agze ones here if you want... pm me an offer
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
WHEELS, TYRES & SUSPENSION!
www.platinumwheels.co.nz
tsoob
Postby NOLAW » Wed Sep 22, 2010 6:38 pm
iv got some 550cc ones if your interested
NOLAW
Postby rx7guy » Thu Sep 23, 2010 6:30 pm
Altezza beams?
The torque band is wide and the road is narrow
rx7guy
Users browsing this forum: Bing [Bot] and 23 guests
