Malcolm wrote:I didn't know they had maths on waiheke
l1ttle_d3vil wrote:You can put some 550cc RX7 Injectors in. They'll bolt straight in with no mods needed, and instantly give you about 50% more fuel. I run them in my road car, but I occasionally drag it too.
matt dunn wrote:What ECU do you plan to use, as if you go to larger injectors you will need an aftermarket ECU.
