Replaced faulty voltage regulator but still no charge :(
Postby cat007 » Sun Oct 03, 2010 7:02 pm
So I replaced the voltage regulator that had a visibly broken bit inside - but there's still no charge going to the battery.
I'm guessing now, the thing to replace, or at least inspect would be the alternator....
Seems strange that the alternator would blow at the same time as the voltage regulator?
Does anyone know what other cars I could find a replacement alternator on, for a 1987 Hiace with a 4Y engine....
I'll take a trip to pick a part next weekend
Thanks
Hunt
Postby Bling » Sun Oct 03, 2010 7:09 pm
How many volts @ battery when van is running?
Postby cat007 » Sun Oct 03, 2010 9:19 pm
BZG|Bling wrote:How many volts @ battery when van is running?
Next to nothing - under 1v
Postby Bling » Sun Oct 03, 2010 10:59 pm
8O
How can there be <1v at battery :?
Postby cat007 » Mon Oct 04, 2010 7:13 am
BZG|Bling wrote:8O
Ok at either of the batteries there's 12.6v. I have a blocking diode so at the alternator Side of the diode there's <1v
Hunt
Postby matt dunn » Mon Oct 04, 2010 9:46 pm
there will be a 3 wire plug to the alternator as well as the main B+ stud.
What voltage do you get on the wiring with the alt unpluuged and the ign on? One wire should have power with the key on, the other two wont.
Postby cat007 » Wed Oct 06, 2010 5:38 pm
matt dunn wrote:there will be a 3 wire plug to the alternator as well as the main B+ stud.
Thanks for that!
I'll check this when I get home tonight. I should be checking this without the engine running and the IG turned to ON yeah?
Postby matt dunn » Wed Oct 06, 2010 6:00 pm
yeah.
Postby cat007 » Wed Oct 06, 2010 7:04 pm
Ok out of the 3 pins - the two that a side by side, have 13.3V on (i.e. full battery voltage) and the 3rd pin on the plug has 6.3V on....
I tested the plug without it being plugged into the alternator....
Should I plug it in and try and test? Would that change anything?
Postby cat007 » Thu Oct 07, 2010 11:39 am
Also I should point out that the old voltage regulator looked like this:
The new one, however, doesn't have the big bit on the top (which appears to be a giant relay) and looks like this (although it's in a plastic case, not metal):
I'm guessing it's different because it's newer and we have better solid state tech than we did back in 1987?
Postby cat007 » Sat Oct 09, 2010 10:38 am
Any idea's peeps?
Postby cat007 » Sat Oct 16, 2010 10:42 am
What else could be causing this? If I'm getting voltage where I shouldn't on the alternator, what could that be?
Postby matt dunn » Sun Oct 17, 2010 9:45 pm
Been a while since I did much with the old externals,
but I would have expected only one power fed to the alt in that 3 pin plug.
Are you sure the reg is the right one as there about 6 different versions that all look identical.
Postby cat007 » Tue Nov 09, 2010 4:12 pm
matt dunn wrote:Been a while since I did much with the old externals,
I'm pretty sure it's the right one. Unfortunately I have intelligently lost the receipt. It's not a toyota part but is supposed to be a 'match'.
I'll check everything either later tonight or tomorrow evening when I get a chance and get all the model numbers etc.
It does seem very odd that I'm getting +12v on 2 of the pins and 6 on one. Maybe I should test what voltage, if any, I'm getting on those same pins without the regulator plugged in...
Postby NZ_AE86 » Tue Nov 09, 2010 10:13 pm
cat007 wrote:Ok out of the 3 pins - the two that a side by side, have 13.3V on (i.e. full battery voltage) and the 3rd pin on the plug has 6.3V on....
Where you probing the Alternator or the plug when you did this?
Current rides;
1985 AE86 Race/Rally Car
1986 Levin GT
NZ_AE86
Postby cat007 » Wed Nov 10, 2010 7:25 am
I was probing the plug.
