soarer 300xxx kms issues?
Postby UTERUS » Tue Sep 28, 2010 2:46 pm
Yea JZA80 shiz will bolt in for no gain whatsoever, unless it was cheaper than soarer parts.
JZA80 coilovers fit though 8)
If you intend to trackday it, swapping the front upper arms side to side will allow you to run more castor without sacrificing camber.
Also, manual it asap, best thing i ever did.
UTERUS
Postby gmacrae » Wed Sep 29, 2010 9:28 am
headshotnz wrote:
Dell'Orto wrote:PS pump leaks, dripping onto the alternator and rooting it
Yeah.. so this is true..
Stupid v8 costing me lots of petrol and now doesnt go.. farrkk.
Its usually just the idle up valve on the PS pump that leaks for memory. Pull the valve out, remove/cap the hoses up at the intake/mainfold and wind a sump plug into the PS pump with some loctite in place of the valve
gmacrae
Postby phoenix » Wed Sep 29, 2010 10:35 am
Mr.Phreak wrote:
phoenix wrote:Both Z30 and A80 arms available ~320 each new but Z30 ones aren't stocked in NZ.
Since when??
Hell of a price drop from the last time I checked
I did mine in May this year, sourced through Mark. Maybe he just likes me more than you? :lol: Or maybe you got quoted the later model alloy lower arms that the A80 uses?
phoenix
Postby Mr.Phreak » Wed Sep 29, 2010 1:37 pm
gmacrae wrote:Its usually just the idle up valve on the PS pump that leaks for memory. Pull the valve out, remove/cap the hoses up at the intake/mainfold and wind a sump plug into the PS pump with some loctite in place of the valve
Nah, it's the idle up that causes fluid to disappear, the seals die in the pumps which make a mess (apparently not helped by high revs on hard lock)
Not a hard job to strip out and clean, just depends how long it's been doing it as it tends to chew out the the slip ring instead of the bushes.
phoenix wrote:I did mine in May this year, sourced through Mark. Maybe he just likes me more than you? :lol: Or maybe you got quoted the later model alloy lower arms that the A80 uses?
Haven't priced for a long time, and didn't ask about the JZA80 arms but Z30 ones were moonbeams. And Mark likes everyone more than me :cry:
Mr.Phreak
Postby 1I1 » Wed Sep 29, 2010 1:49 pm
Damn straight :lol:
TRD Clicky >>Here
1I1
Postby Mr.Phreak » Wed Sep 29, 2010 8:54 pm
:lol: Cheers for today anyway
Mr.Phreak
Postby Mr.Phreak » Fri Oct 01, 2010 9:38 am
Mmmmmm, toys..... (Boring as hell but yay for parcels)
Mr.Phreak
Postby headshotnz » Sun Oct 03, 2010 8:45 pm
I removed the alternator today, i have a second hand one which i can get for 230 but i can get cheap parts and labour for this job so ill price that up too.
What is the normal cause of leaking power steer fluid and what should i do to prevent it from happening again?
Current: UCF20 NZ New LS400,
(Current project) Gen II SW20 Turbo (MR2 v0.5Beta currently in the works)
Previous: Ae101 trueno (S/S), ST185 Group A, Accord with adjustables and H22a certed. SW20 (ct20b, blitz ecu) Uzz30, ae101 s/s 20v c56(-04c;) ) lsd, ae100 beast 5afe(for maximum horsepowers)
headshotnz
Postby Mr.Phreak » Sun Oct 03, 2010 9:32 pm
Mr.Phreak
Postby headshotnz » Sun Oct 03, 2010 11:53 pm
Cheers mate, seems relatively easy considering it breaks the alternator.. should i put a rag over the new alternator when i put it in so i can drive my car to the workshop (way easier to do the work there..)
headshotnz
Postby headshotnz » Thu Oct 07, 2010 8:45 pm
Hey every one, i took my alternator down to autostop (i know i know.. ;) ) they said alternator is working fine, so i reinstalled the alternator started car. still has same problem..
Symptoms:
Sounds to be running on 4-7 cylinders.
smells rich, i can smell the gas.
"Alternator not charging Battery " light comes up on dashboard.
idles at normal, if i put my foot down any more the rev counter(digi dash) drops to 0, even though the car is running.
Im thinking possibaly AFM or coil pack...
Please excuse my ignorance ive only owned a 20v.. :D hahaha
headshotnz
Postby Mr.Phreak » Thu Oct 07, 2010 9:23 pm
Sounds like a coil, try disconnecting them one at a time.
Mr.Phreak
Postby headshotnz » Thu Oct 07, 2010 10:47 pm
Mr.Phreak wrote:Sounds like a coil, try disconnecting them one at a time.
Cheers mate, will do first thing tomoro aswell as a diag test.
headshotnz
Postby iOnic » Fri Oct 08, 2010 8:45 am
Check your battery voltage while the car is idling.
Postby UTERUS » Fri Oct 08, 2010 6:56 pm
Get a replacement alternator and AFM, they are likely $&#$%.
Autostop, seriously?
UTERUS
Users browsing this forum: No registered users and 39 guests
