3sge exhaust ports
3sge exhaust ports
Postby Townace » Thu Oct 07, 2010 9:26 pm
whats the spacing of the exhaust ports of a gen 2 engines vs altezza beams? could a gen 2 exhaust flange be welded to factory altezza extractors as a cheap gen 2 rwd exhaust option?
Townace
Postby Akane » Thu Oct 07, 2010 11:10 pm
nope, different bolt pattern :(
Postby RomanV » Fri Oct 08, 2010 7:21 am
You sure you read the question Akane? :P
Not sure about the exhaust side spacing, but I know that the intake port spacing is a bit different, I would assume the exhaust side is the same.
Postby Akane » Fri Oct 08, 2010 2:25 pm
RomanV wrote:You sure you read the question Akane? :P
No I don't :oops:
Nah they're slightly off IIRC. So it still stands as a no to a "good and cheap" mod.
Postby Townace » Fri Oct 08, 2010 4:05 pm
bugger cheers
Townace
