Brake drum puller
Brake drum puller
Postby -Justin- » Wed Oct 13, 2010 12:56 pm
Anyone got one of these i can borrow, my mums car's drums are rusted on nicely :D
-Justin-
Postby edwagon » Wed Oct 13, 2010 2:28 pm
What kind of vehicle is it?
There is often/usually a couple of threaded holes between the wheel studs which you can wind an m8 bolt into, which will bottom out on the hub, pressing the drums off.
Firstly tho, spray some crc around the centre spigot, and into the stud holes, wait 5 mins and then give the front of the drum a good whack with a hammer - they should jump off!
And make sure the handbrake is off! :lol:
edwagon
Postby Bling » Wed Oct 13, 2010 3:01 pm
Yeah bolts is the easiest way. Will get really tight, then *click* and you're done 8)
Postby touge_ae101 » Wed Oct 13, 2010 4:53 pm
+1 for bolts.
touge_ae101
Postby Mr Revhead » Wed Oct 13, 2010 4:58 pm
Running some emery tape around the spigot if there is room will also help. get rid of any rust/scale etc
Postby Akane » Wed Oct 13, 2010 5:28 pm
Never had a problem with the good ol' whack it till it drops.
Postby CelicaGT8 » Wed Oct 13, 2010 6:43 pm
CelicaGT8
Postby Emperor » Wed Oct 13, 2010 10:14 pm
Emperor
Postby Bling » Wed Oct 13, 2010 10:43 pm
Just assume its a quote :wink:
Postby UTERUS » Wed Oct 13, 2010 10:59 pm
Think you're hitting it hard enough? You're not, smash it harder you pussy.
UTERUS
Postby rollaholic » Thu Oct 14, 2010 7:38 am
helps if the shoes are adjusted right off as well, old drums can develop a lip on the inside so they will turn freely, but still catch on the shoes when ya try and pull them off
and on some cars the drum and hub are one and the same!
Postby Akane » Thu Oct 14, 2010 5:06 pm
UTERUS wrote:Think you're hitting it hard enough? You're not, smash it harder you pussy.
What he said.
Postby YeMs » Thu Oct 14, 2010 6:18 pm
What he said.
i 3rd that. has worked for me every time, and iv done hundreds of rear brake jobs
Your local Hybrid Elite tech
YeMs
Postby Quint » Thu Oct 14, 2010 9:02 pm
If the hammer isn't working.
Get a bigger hammer.
Quint
Postby Bling » Thu Oct 14, 2010 9:51 pm
I had some stubborn ones the other day.... and I hit them pretty hard :lol: No dice, had to hunt around for some bolts, then cursed at how easy it was compared to the bashing :x
Postby rollaholic » Fri Oct 15, 2010 7:47 am
smashing the shit out of anything that wont move is poor practise :P
its all about technique!
Postby YeMs » Fri Oct 15, 2010 8:56 am
rollaholic wrote:smashing the shit out of anything that wont move is poor practise :P
i dunno.. when it comes to drums you cant beat the ol' tappidy tap. it loosens all the rust around the spigot, also loosens all the brake dust sitting on the shoes which actually grips the drum when you are trying to put it off.
i have seen people use the bolt procedure and they have destroyed springs/retainers. if tapping it doesnt get it off, then de-adjusting the shoes is the next option and another tap.
YeMs
