Ping Ping 3sgte
Ping Ping 3sgte
Postby CelicaGT8 » Wed Oct 13, 2010 6:37 pm
Sorted out my engine missfire (rotor, cap, king lead)
I have turned up the boost on my st171 corona wagon, 3sgte with ct27 (pics of turbo upgrade in the link below) but now when i floor it with 13ish psi it pings like hell, scary stuff! (goes like hell too tho hehe)
Its running a standard st185 pump, but the fuel lines are smaller (using carby lines) could the pinging be due to lack of fuel? injectors too small?
Its timed to 10deg btdc and im running 95octane.
CelicaGT8
Postby iOnic » Wed Oct 13, 2010 6:46 pm
Check the fuel pressure and test the flow rate. The pumps don't flow as much as they get older - smaller lines won't help either. Would pay to get the injectors cleaned as well.
Postby Dell'Orto » Wed Oct 13, 2010 6:48 pm
^ that.
Postby CelicaGT8 » Wed Oct 13, 2010 7:04 pm
Have checked the fuel pressure, about 40psi at idle, but i dont no what its doing when im driving... cleaning injectors is pricy?
CelicaGT8
Postby Bling » Wed Oct 13, 2010 7:36 pm
PM Matt Dunn if you want to get them cleaned :)
Postby levinguy » Wed Oct 13, 2010 7:39 pm
see how long the fuel pump pumps un regulated, chuck the fuel feed in a bucket, time it for a minute. think it should be 180 l/hour? duno.
levinguy
Postby CelicaGT8 » Wed Oct 13, 2010 8:12 pm
So your pointing to fuel??
CelicaGT8
Postby levinguy » Wed Oct 13, 2010 8:13 pm
yes.
levinguy
Postby iOnic » Wed Oct 13, 2010 8:19 pm
What sort of intercooling do you have?
Postby CelicaGT8 » Wed Oct 13, 2010 8:21 pm
Have a good sized front mount, 2.5" piping, pictures on my projects page. Its over kill i think, so should be ok
CelicaGT8
Postby Heylin » Wed Oct 13, 2010 9:43 pm
My MR2 was pinging its ass off on CT20b @ 16psi. Stock fuel pump was flowing 135 LPH (same a NA corolla).
New they flow 180LPH but from about 180,000 kms onwards chances are they are wearing out and slowing dying.
Heylin
Heylin
Postby CelicaGT8 » Thu Oct 14, 2010 4:53 pm
poor car, what flow rate would you all recomend? over 200 lph?
CelicaGT8
Postby strx7 » Thu Oct 14, 2010 5:01 pm
CelicaGT8 wrote:poor car, what flow rate would you all recomend? over 200 lph?
MSD pump off trade me. I have personally tested one of these pumps at 240LPH @ 60psi.....
Postby iOnic » Thu Oct 14, 2010 5:01 pm
Depends on the pressure as well. A stock 3sgte pump flows around 200lph at 35psi and supports up to 60psi fuel pressure (40psi base pressure + 20psi boost) before it falls flat on it's face and is only flowing around 150lph. At idle/base fuel pressure it should be flowing around 190lph.
Postby Akane » Thu Oct 14, 2010 5:03 pm
Whinebro 255lph, cheap and effective.
Postby levinguy » Thu Oct 14, 2010 5:25 pm
Akane wrote:Whinebro 255lph, cheap and effective.
i agree. oh and i happen to have one for sale. $500
levinguy
Postby CelicaGT8 » Thu Oct 14, 2010 6:54 pm
i agree. oh and i happen to have one for sale. $100
Sold!
CelicaGT8
Postby phoenix » Thu Oct 14, 2010 7:27 pm
levinguy wrote:i agree. oh and i happen to have one for sale. $500
Is it gold plated?
phoenix
Postby iOnic » Thu Oct 14, 2010 7:29 pm
LOL that's almost $300 too much
Re: Ping Ping 3sgte
Postby iamawesome » Thu Oct 14, 2010 8:59 pm
CelicaGT8 wrote:and im running 95octane.
well here's your first problem.
iamawesome
Users browsing this forum: No registered users and 26 guests
