If I do go for it, the pipes will be properly slash cut stainless with a stainless heatshield of some description riveted to the skirt. The car may also be washed. Possibly.
Thoughts?
d1 mule wrote:there are rules governing the distance the exhaust has to exti behind the rear most door, i think itssomewhere from 200-300mm from memory, which may be hard on the mr2 but apart from that DO IT!!!!!!!!!!!!
iOnic wrote:Ground clearance and I stopped being friends a long time ago.
touge_ae101 wrote:obviously you avoid the square like a plague, there is no way you could get through some of those potholes like that ^^
5. The exhaust system is so constructed that emitted heat or fumes are likely to harm vehicle occupants, eg the exhaust gases are not directed away from the perimeter of the vehicle’s passenger compartment.
