GTT Drag Time
GTT Drag Time
Postby BZG Wagon » Sun Oct 17, 2010 11:01 am
Taking my standard / factory spec manual Caldina GTT down to the drags in a few weeks. What would be a good time to aim for?
I'm guessing they'd do around a mid 14?!?
Also the start - is it worth 'launching it' (given I don't want to break it)? Or just a high rev slip the clutch type start?
BZG Wagon
Postby cat007 » Sun Oct 17, 2010 12:43 pm
What clutch have you got in it?
Make sure there's someone on the start line videoing you! :)
Postby GTTpower » Sun Oct 17, 2010 1:02 pm
Flat 14's are the factory quoted 1/4 mile time. Id say about there if you know what your doing shifting wise.
Pump your tyres up hard (35-40psi) if you want to reduce stress on the drivetrain, also if you can, take out the boat anchor rear seats.
You going to the first nightspeeds? Mate of mine is hopefully coming along with his 3SGTE powered ST195 to go for the 4wd caldina record :P
1999 SXE10 Altezza RS200Z
2004 Honda SCV100
Steam/Origin ID: nzEP85
GTTpower
Postby metal_sean_head » Sun Oct 17, 2010 1:50 pm
Depends if you granny shift or double clutch like you should.
VTEC: All of the lag and none of the boost.
89 AE92 FXGT
Big Port Redtop
TVIS!
19.8@32kph
metal_sean_head
Postby dnalunchie » Sun Oct 17, 2010 2:33 pm
metal_sean_head wrote:Depends if you granny shift or double clutch like you should.
Your ganna be lucky if that second shot of NOS doesnt blow apart you highcomp 3sgte, PERIOD!
EX:89 RS and GT Legacys, 90 EF9 Civic, 95 Integra R, 95 AE101, 90 ST185, 88 Accord, 87 3rdoor and 5door Swift hatch, 91 Pontiac Lemans, 80 Liftback Celica, 95 Hornet 250
Current: 90 3sfe Corona
dnalunchie
Postby DXROLLA » Sun Oct 17, 2010 2:42 pm
Doesnt matter if it does you can get over night parts from japan
DXROLLA
Postby dnalunchie » Sun Oct 17, 2010 2:44 pm
DXROLLA wrote:Doesnt matter if it does you can get over night parts from japan
tehehehe
dnalunchie
Postby Bling » Sun Oct 17, 2010 3:40 pm
If you didn't want to brake it, you wouldn't be launching a 4wd :lol:
Just make sure the manifold is bolted up tight as you won't want it dropping out of the passenger foot well. :lol:
Postby BZG Wagon » Sun Oct 17, 2010 4:01 pm
LOL! The dreaded manifold warning...
I'm lining it up against my firends dads ver5 STI, and another mates 2dr R33 GTS25T Skyline.
All 3 cars are standard & similar years, so there won't be any seat unbolting :D. I expect the STi will be out in front, and not sure how I'll go against the skyline. Should be a fun night.
My clutch is factory (as far as I'm aware). 140kms on the clock - I want to be reasonably gentle on it. First time racing at the drags too.
I was thinking:
* Oil change the weekend before.
* 1/4 tank of petrol.
* 38 - 40 psi in the tyres (esp. hard at the rear).
* Load the car up on the handbrake when the lights start, drop handbrake & slip clutch until car is moving - then go for it.
Why would I double clutch? Wouldn't that slow you?
BZG Wagon
Postby 3T-Rona » Sun Oct 17, 2010 4:11 pm
BZG Wagon wrote:Why would I double clutch? Wouldn't that slow you?
Watch The Fast And The Furious a couple more times.......
PM me for anything autoelectrical, Info or jobs etc....
3T-Rona
Postby dnalunchie » Sun Oct 17, 2010 4:24 pm
BZG Wagon wrote:LOL! The dreaded manifold warning...
I was thinking:
This may be slightly pedantic but wouldn't you risk potential fuel starvation if you ran too dry in the fuel tank considering the G-forces?
dnalunchie
Postby GTTpower » Sun Oct 17, 2010 4:45 pm
Your better off running a 1/2 tank, bugger all difference seeing as your not taking out any interior which contributes most of the removable weight.
Agree on running hard in the rear, don't want any of this front wheel spin bullshit.
Doubt you'll beat the STi unless you put a curse on its gearbox, and the skyline have you at the top end so you'll have to beat him on the launch
2004 Honda SCV100
GTTpower
Postby metal_sean_head » Sun Oct 17, 2010 4:54 pm
And it doesn't matter if you win by an inch or a mile. Winning's winning.
89 AE92 FXGT
Big Port Redtop
TVIS!
19.8@32kph
metal_sean_head
Postby Al » Sun Oct 17, 2010 5:18 pm
dnalunchie wrote:This may be slightly pedantic but wouldn't you risk potential fuel starvation if you ran too dry in the fuel tank considering the G-forces?
Yes it is too pedantic.
However with the earth stopping torque a standard GTT produces I understand your concern.
Al
Postby metal_sean_head » Sun Oct 17, 2010 5:27 pm
Lucky its not a 4AGE. With the amount of torque they make you would need to have a full tank to prevent starvation.
89 AE92 FXGT
Big Port Redtop
TVIS!
19.8@32kph
metal_sean_head
Postby dnalunchie » Sun Oct 17, 2010 5:34 pm
Yeah if it was any other car i wouldn't worry, its just i know how much rawr power a 3sgte can make
dnalunchie
Postby RedMist » Sun Oct 17, 2010 5:38 pm
Double clutch? Only if you're trying to be both slow and destructive on your drivetrain!
Double clutching is for non synchro, dog boxes on downshift. And then only necessary on older style dogs... like those found in heavy trucks.
If you want to be fast then it's smooth and quick that'll get you the lowest time. You can be a little quicker by punishing your clutch on launch and slip it slightly to keep the engine at the highest torque RPM. But disengaging the clutch letting the engine build up RPM and let it bite again isn't the way to be fast in any motorsport.
Personally I like to lanuch on a trailing throttle. By blipping the throttle and letting it fall just before launching means the engine is rich and in a high torque situation. With low RPM it also means that if there is slip its minor (as the engine isn't on cam). I've used this technique with my race cars from a NA cammed to hell 4AGE to my grunt monster VQ35.
You'll also need to chase the throttle. Don't slam it wide open, put about half throttle into it then chase up the RPM with more throttle. As the RPM increases the air required by the engine is increased. We got 12% more power from a G13 on the dyno by simply chasing up the throttle. It may take some practice, but just put throttle in smoothly and count out a few seconds (while continuiously putting in more throttle) before hitting the throttle stop. Remember that smoother is quicker.
The answer is Helmholtz!
Toyota ST185 Celica Rally.
Toyota ST205 Celica Rally.
RedMist
Postby Malcolm » Sun Oct 17, 2010 6:08 pm
BZG Wagon wrote:* Load the car up on the handbrake when the lights start, drop handbrake & slip clutch until car is moving - then go for it.
nononononono. no.
Don't use the handbrake, definitely don't "load it up on the handbrake". Roll up, stop (using the foot brake), make sure you're fully stationary, then take your foot off the brake and don't touch it again until after you go through the speed trap.
If you're going to slip the clutch (I wouldn't) then don't pump the tyres up so high because you wont be stressing the drivetrain that much anyway, leave them at a normal pressure that you use for everyday driving.
When I dragged my ST185 I just held it around 6K, then sidestepped off the clutch and put my right foot flat. Good enough for 1.7 60 foots, but it did eventually cost me a gearbox.
Postby cat007 » Sun Oct 17, 2010 7:16 pm
Malcolm wrote:When I dragged my ST185 I just held it around 6K, then sidestepped off the clutch and put my right foot flat. Good enough for 1.7 60 foots, but it did eventually cost me a gearbox.
Try that with a standard 140K clutch....
Postby iOnic » Sun Oct 17, 2010 7:32 pm
If you want to get off the line as quickly as possible in an AWD car you're gonna have to leave your mechanical sympathy at home. If you actually care about being able to drive the car afterwards then just drive it off the line and focus on getting your shifting right during the run.
