gen 3 3sge cams in gen 2 3sgte
Postby CelicaGT8 » Tue Oct 19, 2010 12:12 am
gen 3 3sge cams in gen 2 3sgte = more power?
Bigger lift, more duration? more hp?
Worth doing?
CelicaGT8
Postby iOnic » Tue Oct 19, 2010 7:05 am
Worth doing if you get the right ones. More power....maybe slightly but nothing night/day
Gen2
3SGE (165ps):
In: 244deg, 8.5mm lift
Ex: 244deg, 8.5mm lift
3SGTE (225ps):
In: 236deg, 8.2mm lift
Ex: 236deg, 8.2mm lift
Gen3
3SGE A/T (170ps):
In: 240deg, 8.7mm lift
Ex: 240deg, 8.2mm lift
3SGE M/T (180ps):
In: 252deg, 9.8mm lift
3SGTE (245ps):
Postby kim0663 » Tue Oct 19, 2010 1:14 pm
are you completely sure those are accurate? hmm
Mr2 GT-S
330ci M
kim0663
Postby Akane » Tue Oct 19, 2010 1:32 pm
kim0663 wrote:are you completely sure those are accurate? hmm
I posted a copy & paste before I think, from mr2oc.
I can confirm that Gen 3 3S-GE M/T is the stuff you want.
You can put 2 x intake cams in there and degree it properly, epic broooooooom pshshshhshhhhhhhhhhhhh au bro!
BTW bring your laptop around sometime need to retune my car, now it's idling low after the danger to manifold fix! boosting really high too might as well throw in the Gen 3 Map sensor?
Postby EssDub » Tue Oct 19, 2010 2:48 pm
With the Gen3 cam, wouldn't you risk spitting shims?
1992 SW20 MR2 GT-S Turbo
Previous Rides: Mazda 323, Toyota Levin BZ-G, 1992 SW20 MR2, 1994 Gen3 SW20 MR2 T-Bar
EssDub
Postby Akane » Tue Oct 19, 2010 2:56 pm
Maybe, depends how big your balls are and how high you wanna rev (you DO wanna rev higher to take advantage of the high lift), the HKS 264 cams are 9mm / 9.2mm according to HKS USA, with 9.8mm lift, you're right, I wouldn't go there.
Gen 2 is for fags anyway :P
Postby EssDub » Tue Oct 19, 2010 3:58 pm
Akane wrote:
Gen 3 is for fags anyway :P
Wow, Dude, never expected you to be that honest :P
EssDub
Postby Adamal » Tue Oct 19, 2010 5:06 pm
I reckon. Who the hell wants a better flowing head? Overrated :P
Postby iOnic » Tue Oct 19, 2010 6:10 pm
They're accurate as far as I'm aware. You won't spit shims out with any stock 3S cams unless you raise the rev limit in which case you should be doing springs and a shimless/shim under bucket setup anyway.
Postby RomanV » Tue Oct 19, 2010 6:29 pm
Adamal wrote:I reckon. Who the hell wants a better flowing head? Overrated :P
Yeah if you're wearing a helmet, it's a moot point how aerodynamic your head is anyway.
Postby Celica RA45 » Tue Oct 19, 2010 9:29 pm
gen 2 shim on top, gen 3 shim under bucket ,gen 4 and 5 shim under bucket as well
Celica RA45
Postby Malcolm » Tue Oct 19, 2010 10:07 pm
or if you're a closed roof vehicle, the whole thing becomes completely irrelevant
Postby CelicaGT8 » Wed Oct 20, 2010 11:09 am
Interesting... no chance of hitting the pistons?
I only rev to 8, i behave.
any marknings on the head etc to see if its a manual one?
So you can achually put 2 intake cams in... work well?
CelicaGT8
Postby Akane » Wed Oct 20, 2010 4:06 pm
Oh wow. This is gonna end so badly.
<3
