Bilstein Circlip Height Shocks - JZX100
Postby Tofu » Wed Oct 27, 2010 6:38 pm
Hi Lads,
Does anybody know if Bilstein manufactures circlip height adjustable shocks for JZX100's? If so, what is the part number?
Trying to get around needing a low volume cert for the chaser and they should match well with my existing TRD springs.
If anybody can help that would be great!
Sample of what it looks like:
Thanks,
Phil
[WAAA] - 98' JZX100 Chaser Tourer V
Tofu
Postby ChaosAD » Wed Oct 27, 2010 6:42 pm
While not adjustable while fitted to the car they are still height adjustable and will most likely require a cert.
ChaosAD
Postby Tofu » Wed Oct 27, 2010 10:06 pm
Actually I think you are right in them requiring a cert. Found this in the lvv guidelines
'springs and seats must not be height adjustable'
I was under the impression that it would only need a cert if it the spring sat on a thredded sleeve and could be adjusted whilst still attached to the car.
Thanks for the heads up ChaosAD. Will go back to the drawing board however I would still prefer this setup over any coilover in that price range.
Tofu
Postby Looonie » Sun Oct 31, 2010 4:36 pm
If you want to know, bring me some jack & coke premix and I'll jack up the car for you to note the part # ;)
Rumple dee pumple dee doo...
Looonie
Postby TRD_ZERO » Tue Nov 02, 2010 10:07 am
A friend of mine has a set of them in his evo and the guy that built them for him said no cert needed.
Previous:
TRD_ZERO
