why does my silver top fxgt sound like a diesel ute?
Postby krock » Mon Nov 01, 2010 3:07 pm
Engine has a slight tick, kind of like a diesel ute? car has done 160km.
Is this a common problem with silver top 4ages? Is it tappets or something like that?
Any ideas on what to look at would be awesome,
ps. have searched but couldn't see anything that seemed relevant
krock
Postby sergei » Mon Nov 01, 2010 3:20 pm
Most likely your VVT pulley is stuffed.
Postby touge_ae101 » Mon Nov 01, 2010 3:21 pm
can be a small exhaust leak if it is really noticable. (normally between the two sections of headers) or cracked headers. have had this a couple times after having everything apart.
or if its more of a refined tick it could be the vvt pulley rattle. not alot you can do about that except buy another one from our sponsor. not cheap though and has no effect on the engine with the rattle.
touge_ae101
Postby sergei » Mon Nov 01, 2010 3:26 pm
VVT pulley does not "tick", it does sound just like diesel (it "tacks"). Very common problem.
Postby strx7 » Mon Nov 01, 2010 3:30 pm
if it "sounds like a tractor" then its usually the VVT pulley
Postby deaf_rattle » Mon Nov 01, 2010 5:02 pm
all 20vs ive heard sound like diesels anyway. even if the pulley is fine.
Postby RS13 » Mon Nov 01, 2010 5:15 pm
If its' doing it at idle only, chances are its' the VVT pulley.
Take the plug off the VVT oil solenoid on the front of the motor, and with the motor idling, put 12V onto the solenoid. If the rattle stops, and the revs drop a bit, its' the pulley thats' stuffed. Having a worn pulley doesn't do any harm to the engine, just sounds ugly!
I got a retail quote for a brand-new pulley a couple of years back for my FXGT, was over $1000.. or a second-hand one from a low-k motor for $50 from a wrecker, the one I ended up with still had a slight rattle but nowhere near as bad as the original.
RS13
Postby whynot » Mon Nov 01, 2010 7:05 pm
i'm pretty sure my one had the vvt rattle and I masked it by putting some dyna mat sound proofing in the cambelt cover, go figure.
whynot
Postby krock » Mon Nov 01, 2010 7:50 pm
awesome cheers guys!
is changing the pulley a major job? can it be done with basic tools by someone with basic handyman skills?
also how is the best way to get 12v on to the solenoid ? :oops:
krock
Postby sergei » Mon Nov 01, 2010 7:59 pm
krock wrote:awesome cheers guys!
Technically if it is not too loud just leave it in peace.
Getting 12V to solenoid can be tricky if you never played with wires before ;).
Otherwise replacement of said part is like 1/2 - 3/4 of cambelt job. You could actually slide it out and slide it back in, without taking off the cambelt, but that can be very tricky/dodgy.
Postby krock » Mon Nov 01, 2010 8:05 pm
ok i get it. yeah probably best not to worry about it if isn't affecting the engine negatively
cheers!
krock
Postby soopachargen » Tue Nov 02, 2010 3:24 pm
best way to get rid of it is to turn your stereo up
When in doubt, down and out.
soopachargen
Postby FANGIN » Tue Nov 02, 2010 3:36 pm
deaf_rattle wrote:all 20vs ive heard sound like diesels anyway. even if the pulley is fine.
Yea, but atleast they don't blow head gaskets :wink:
Mine's been rattling for the past 2.5 years, but hasn't skipped a beat.
1998 AE111 Carib - For Sale!
1999 JZS161 GS300 - Tow Wagon
1986 FC3S - 410wkw Drag / Track Toy
FANGIN
