WTF is it and WHY is it on my 1UZ
Postby CelicaGT8 » Tue Nov 02, 2010 12:03 am
Ok so i went to levinguys for a drink or 6 and nextt thing i no theres this thing bolted to my 1uz, so WTF is it and WHY is it on my 1UZ, and why is it there, and can i remove it and what does it do and why does it do it, and wyh is it on there in the first place?
ps, what does it do?
I WAS SUPPOSE TO PAINT IT, AND CIRCLE IT BUT I FORGOT
SO ITS THE THINGY ON THE RIHT HAND SIDE WITH THE PIPES AND THE PULLY, its random, like what is it for/
hydrolic pump? its so vivid
here we og
CelicaGT8
Postby Bling » Tue Nov 02, 2010 12:05 am
I'm disappointed, I was expecting to see a large supercharger attached to the top :(
Not sure what that is though sorry.
Postby Truenotch » Tue Nov 02, 2010 12:05 am
It's an oil pump for the fan I think.... 1UZ's run a hydraulic fan instead of Viscous.
Awesome post by the way :D .
Truenotch
Postby CelicaGT8 » Tue Nov 02, 2010 12:06 am
Charger goes on top, achually have one for it now too, just need to atach,...... dam stupd thing on the side, its crazy, what does it do! WHAT DOES THIS MEAN!
CelicaGT8
Postby CelicaGT8 » Tue Nov 02, 2010 12:07 am
Truenotch wrote:It's an oil pump for the fan I think.... 1UZ's run a hydraulic fan instead of Viscous.
bUT WHY
all that bs foir a dam fan! can i remove it,
CelicaGT8
Postby Truenotch » Tue Nov 02, 2010 12:13 am
Yeah, you can remove it but you'll probably need to block something off - never done it before.
You might get double rainbows coming out of your engine, not sure.
Truenotch
Postby siren676 » Tue Nov 02, 2010 12:19 am
Could it be aircon or power steering?
siren676
Postby CelicaGT8 » Tue Nov 02, 2010 12:27 am
Na not aircon or power steering ps is on top left, aircon pump i removed, its just raaaaaaandomly there for no reason other than to be a baby monkey riding on a pig baby monkey
CelicaGT8
Postby Truenotch » Tue Nov 02, 2010 12:31 am
:lol:
Truenotch
Postby rollaholic » Tue Nov 02, 2010 8:47 am
dont some jzs have a similar setup (fan oil pump thingee)
Postby thegreatestben » Tue Nov 02, 2010 8:52 am
What's your motor out've, I took a guess at celsior
thegreatestben
Postby sergei » Tue Nov 02, 2010 9:02 am
I never understood the point of hydraulic fan. Electric fan is much more reliable, cheaper and controllable.
But yes, as above it is for fan.
Postby spencer » Tue Nov 02, 2010 10:03 am
On JZ's its part of the water-pump, it can be deleted with a non hydraulic fan water pump. May be able to do the same here?
ms63 crown
spencer
Postby spencer » Tue Nov 02, 2010 10:09 am
after a quick google seems you can, go check out lextreme
ms63 crown
spencer
Postby Mr.Phreak » Tue Nov 02, 2010 10:26 am
sergei wrote:I never understood the point of hydraulic fan. Electric fan is much more reliable, cheaper and controllable.
How is a hydraulic fan not reliable or controllable??
Mr.Phreak
Postby spencer » Tue Nov 02, 2010 10:52 am
Yea the hydraulic fan pressure is ECU controlled, The main benefit is they move more air for less noise, trade off is higher complexity and cost. But they are usually on higher end models so makes sense to me
ms63 crown
spencer
Postby tomtom » Tue Nov 02, 2010 5:05 pm
i took mine off my soarer.its quite easy..just let all the fluid run out and take it all off...you may need to grind the face behind it down so the belt doesnt touch it.
TRUENO gtz! AND 1UZ MANUAL SOARER!
tomtom
Postby CelicaGT8 » Tue Nov 02, 2010 5:58 pm
wow what a night, we need to have toyspeed drinks!
ok... il remove it, just unbolt everything in sight, see what happens, not like theres anything alse i could possibly use it for?
CelicaGT8
Postby al_feinted » Tue Nov 02, 2010 6:31 pm
use it for a hydraulic driven supercharger :?
Project cars: 83 corona tt142, 83 corona mark2 gx61, 82 avante chaser gx61.
www.toycrazy.net
http://toyspeed.blakjak.net/profiles/pr ... hp?id=1408
al_feinted
Postby samlloyd » Tue Nov 02, 2010 8:14 pm
Its starting to even look like a triple hydraulic fan setup
Karl Pilkington On seals - "Its between a fish and a dog."
samlloyd
