Wheel spacers
Wheel spacers
Postby Lurkin » Sat Nov 06, 2010 10:38 am
The 17's Ive have an offset that is a little close to the strut tower for my liking... any ideas on the legality of wheel spacers to sit them out a bit further? i.e. is a cert required? cheers, Roy
Past casualties
1986 4age liftback (sold)
1985 4age aw11 (well crunched)
1993 ae101 gt apex levin (sold)
Lurkin
Postby Adoom » Sat Nov 06, 2010 11:01 am
Pretty sure a cert is required. The spacers have to be attached(semi permanently) to either the wheel or the hub/flange/disc thing.
There has to still be enough stud sticking out that you can wind the wheel nuts on ALL THE WAY, not just a few threads. I think it may be a minimum of 1.5 times the diameter of the stud, so at LEAST 18mm. Or you may find your wheels falling off.
You can get longer studs from drivenperformance
http://www.drivenperformance.co.nz/scri ... roduct=739
Adoom
Postby Looonie » Sat Nov 06, 2010 11:13 am
Wheel spacers need to be bolt on, hub centric on both the hub and the wheel, and certified.
Driven performance has correct ones for Toyota in varying thicknesses.
Rumple dee pumple dee doo...
Looonie
Postby Lurkin » Sat Nov 06, 2010 11:16 am
ok.. consensus seems to be a cert is required = too hard basket. might just keep an eye out for a replacement set of 17's then :(
Past casualties
Lurkin
Postby pc » Sat Nov 06, 2010 11:41 am
When you say "a little close" do you mean it's touching?, 1mm gap?, 5mm gap?
2-3mm should be fine as long as you don't bend the rim.
red car
1/4 mile - 14.683s @ 91.83mph
Manfield - 1:24s
pc
Postby touge_ae101 » Sat Nov 06, 2010 12:19 pm
is it the 17's that are close to the strut or the tyre?
i solved the problem by going to a 205 down from 215. got heaps of clearance now!
touge_ae101
Postby Lurkin » Sat Nov 06, 2010 1:22 pm
oh its far enough away to be safe... as long as the rim doesnt get bent - but... looks a little odd tho, as they sit in abit far. nevermind, sounds like its going to be easier to just change the rim, than add spacers.
Past casualties
Lurkin
Postby iOnic » Sat Nov 06, 2010 2:28 pm
Cost of spacers + Cost of cert < Cost of new rims?
Postby Adoom » Sat Nov 06, 2010 2:37 pm
iOnic wrote:Cost of spacers + Cost of cert < Cost of new rims?
Who buys NEW rims? My last set were $100. And they are swish as :lol:
Adoom
Postby BZG Wagon » Sat Nov 06, 2010 3:00 pm
LOL
Yes but this: Image is your car.
:P
BZG Wagon
Postby iOnic » Sat Nov 06, 2010 6:34 pm
lol yeah didn't mean brand new when I said new rims. You'll be doing well to find 17" wheels with decent offsets/widths for less than the cost of a cert + spacers (~$400-$500)
Postby coupekiwi » Sat Nov 06, 2010 10:06 pm
What the hell.
Just put slip on spacers on.
Go to local mechanic for wofs.
If he complains take them off.
coupekiwi
Postby Adoom » Sat Nov 06, 2010 10:45 pm
LOL
:P
Cosmetic appearance is pretty low on my priority list.
Adoom
Postby Bling » Sat Nov 06, 2010 10:53 pm
coupekiwi wrote:What the hell.
You forgot the "cancel your insurance as it will be void if you stack it and they find them."
Postby h8wrxs » Sat Nov 06, 2010 11:42 pm
mmm i ran 2mm spacers on the 18s i had on my trueno, warrant guys always picked on them though
i solved that by going to 205 from 215
but then i bought 17s anyways
The four seasons in Australia consist of "$&#$% it's hot", "Can you believe how $&#$% hot it is?", "I won't be in today because it is too $&#$% hot" and "Yes, the dinner plate size spiders come inside to escape from the heat."
h8wrxs
Location: travelling to candy mountain with my magical leoplurodon
Postby coupekiwi » Sun Nov 07, 2010 12:12 am
LOL isurance.
I have 4 cars registered on a a student budget.
Have had since 6th form. = 4 years.
@ $400+ per car per year I'v saved about 6.5k.
Cut the springs.
coupekiwi
Postby rollaholic » Sun Nov 07, 2010 7:48 am
besides which, they can only decline claims if the problem with your car was a direct contributer to the accident.
'i dunno, i guess they were on the car when i bought it?'
Postby metal_sean_head » Sun Nov 07, 2010 8:21 am
rollaholic wrote:besides which, they can only decline claims if the problem with your car was a direct contributer to the accident.
Is this true?
Because i got my insurance cancelled because it had aftermarket suspension that they apparently didn't know about. This was after an accident where someone backed into my parked car.
VTEC: All of the lag and none of the boost.
89 AE92 FXGT
Big Port Redtop
TVIS!
19.8@32kph
metal_sean_head
Postby rollaholic » Sun Nov 07, 2010 8:56 am
did they decline the claim as well?
Postby iOnic » Sun Nov 07, 2010 10:08 am
Your car doesn't have to be the cause of the accident. The part of the car that has been modified without their knowledge doesn't even have to contribute to the accident. You can have an exhaust that they don't know about and they'll decline the claim as the car is modified beyond their knowledge. Had it happen to me before when someone cut me off and I hit the curb trying to avoid crashing into them..I had a manual conversion done to the car so my insurance was voided. I daresay that suspension/brakes are always a contributor to an accident anyway regardless of who's at fault.
