4age big port rod bolts same as small port??
Just needing to know if 4age big port conrod bolts are the same as the small port ones???
IH8TEC wrote:thought the rod bolts same bazz.
Dont some early model big ports have a smaller Journal? or is that for the mains not the big ends?
Bolts are the same as far as i know.
The torque spec is the same throughout all the 4age's.
Have played with all models of 4age's and they are the same.
1993 Mitsubishi EVO 1 Racecar
1989 AE91 FX-ZS (Previous)
Custom Works Automotive
http://www.HCCC.org.nz
Bazda wrote:IH8TEC wrote:thought the rod bolts same bazz.
The big ends and mains are 40mm on early bluetops and a few early "bigport redtop" engines (7 rib block but still 40mm).
The later redtops, smallports and GZE's are all 42mm.
Pretty sure the bolts are the same though.
