4age big port rod bolts same as small port??
Post Reply
Contact:
Post by Bazda »
Just needing to know if 4age big port conrod bolts are the same as the small port ones???
Post by IH8TEC »
thought the rod bolts same bazz.
Contact:
Post by Bazda »
IH8TEC wrote:thought the rod bolts same bazz.
Dont some early model big ports have a smaller Journal? or is that for the mains not the big ends?
CAMB01
Post by CAMB01 »
Bolts are the same as far as i know.
The torque spec is the same throughout all the 4age's.
Have played with all models of 4age's and they are the same.
1993 Mitsubishi EVO 1 Racecar
1989 AE91 FX-ZS (Previous)
Custom Works Automotive
http://www.HCCC.org.nz
Truenotch
Contact:
Post by Truenotch »
The big ends and mains are 40mm on early bluetops and a few early "bigport redtop" engines (7 rib block but still 40mm).
The later redtops, smallports and GZE's are all 42mm.
Pretty sure the bolts are the same though.
shihad
Post by shihad »
Truenotch wrote:
The big ends and mains are 40mm on a few early "bigport redtop" engines (7 rib block but still 40mm).
really have you seen this with your own eyes?
getting bottled by the friendly Oamaru locals for not doing skids - Coupe Life
Truenotch
Contact:
Post by Truenotch »
Yeah, it was annoying... There aren't too many out there though.
AE82 FXGT
Post by AE82 FXGT »
Truenotch wrote:Yeah, it was annoying... There aren't too many out there though.
my old fxgt was one
Post Reply
