crank pulley remove of engine
Postby gleem » Sat Nov 13, 2010 12:33 pm
need to take a crank pulley of a car at pick a part so i dont have keys etc. can this be done without a impact wrench?
gleem
Postby RomanV » Sat Nov 13, 2010 12:34 pm
Yep, take out a spark plug and fill one of the cylinders with rocks, will stop the engien from turning over all of the way when you undo the bolt. :lol:
They can be a PITA to get off without a gear puller though.
Postby gleem » Sat Nov 13, 2010 12:59 pm
good idea. i never thought of that
gleem
Postby Bling » Sat Nov 13, 2010 1:04 pm
I wouldn't call it a "good" idea :?
Postby Nuty|Mike » Sat Nov 13, 2010 2:42 pm
why not ...sounds good to me
05 Mazda Verisa .....for the Family
Nuty|Mike
Postby neo » Sat Nov 13, 2010 3:07 pm
could just fill the cylinders with water to achieve the compression lock.
If the gearbox + axels + brakes are still there, all you need is 2 people :)
neo
Re: crank pulley remove of engine
Postby sergei » Sat Nov 13, 2010 3:32 pm
gleem wrote:need to take a crank pulley of a car at pick a part so i dont have keys etc. can this be done without a impact wrench?
Is the gearbox off?
If the gearbox off just jam the ring gear with random junk (plenty at pickapart), and unbolt.
if the gearbox is still there, then you can use rope in the sparkplug hole.
If all fails chisel the bolt.
Postby rollaholic » Sat Nov 13, 2010 4:15 pm
RomanV wrote:Yep, take out a spark plug and fill one of the cylinders with rocks, will stop the engien from turning over all of the way when you undo the bolt. :lol:
bahaha, the pickapart mastah speaks
Postby Vertigo » Sat Nov 13, 2010 5:11 pm
agree with a rope in the spark plug hole. just make sure it doesnt fall in.
TVIS just kicked in, yo!
Vertigo
Postby Nuty|Mike » Sat Nov 13, 2010 10:05 pm
its pick a part rocks,nuts,bolts,geese will do the trick
$&#$% i hate the geese at pick a part :evil:
Nuty|Mike
Postby sergei » Sun Nov 14, 2010 8:44 am
Nuty|Mike wrote:$&#$% i hate the geese at pick a part :evil:
Bhahaha for some reason they are ultra aggressive.
I had a thought of snatching one, but how would I get by an angry pacific lady with a goose in my arms....
Postby Mr.Phreak » Sun Nov 14, 2010 9:48 am
Pay her the appropriate value for a goose??
Mr.Phreak
Postby YeMs » Sun Nov 14, 2010 11:12 am
itll be all the gear oil they have been pecking at
Your local Hybrid Elite tech
YeMs
Postby deaf_rattle » Sun Nov 14, 2010 11:19 am
Vertigo wrote:agree with a rope in the spark plug hole. just make sure it doesnt fall in.
yep, used this many a time. usually use a nylon type rope with plenty of length.
Users browsing this forum: Bing [Bot], Google [Bot] and 4 guests
