Newbi wants to learn - Servicing my BZR
Postby loudstealthGT-Four » Sun Nov 07, 2010 10:16 pm
Snaps wrote:^ Good point :lol: If they're in the right places, they should be anyway, but best to check first :wink:
yip i always give my car a good shake when i put it on axle stands
loudstealthGT-Four
Postby Bling » Sun Nov 07, 2010 10:22 pm
I always chuck something else under just in case as well. Might be paranoid, but getting squashed would not be fun! Spare wheel / blocks of wood do.
Postby Tagged » Tue Nov 09, 2010 1:13 am
ahhh i see, lol i originally thought an axle stand can "jack up" the car like a jack does. and now I understand that axle stands are just what they are called...."STANDS" lol
Thanks all for the info! and yes i did find out the proper spot to jack up my AE111, there are two little grooves sitting maybe 8 or 10 cm apart from each other on each side of the chassis, thats where you put the jack in think, read it from a owners hand book or sumthing :)
Tagged
Postby Snaps » Tue Nov 09, 2010 1:05 pm
...Yes, but you should not use a car jack in those places unless you have a block of wood/something with a groove cut into it.
If you jack the car up using the ridge of metal, it WILL bend, you need to jack up on either side of the ridge, which means you need an 'adaptor', if you will :wink:
This only really applies if you're not using the scissor jack that came with the car, as these already have the groove cut into it....
Cheers,
Brandon
Snaps
Postby Bling » Tue Nov 09, 2010 7:01 pm
Just jack it slowly :oops:
I'll make an adapter soon I swear! :lol: Though i'm usually jacking either the whole front or whole rear with a trolley jack so doesn't really matter as not using the factory points.
Postby AE86less » Tue Nov 09, 2010 8:13 pm
Or try making ramps by stacking a few bits of 6x2 timber, much easier :)
I usually change the oil with the car sitting on the ground, it's a wee bit more awkward but I want the sump level so it all comes out.
AE85.5
1GGZE GX81
D21 Navara K/C
AE86less
Mo' Fail
Postby Santa'sBoostinSleigh » Sun Nov 14, 2010 10:23 pm
AE86less wrote:Or try making ramps by stacking a few bits of 6x2 timber, much easier :)
i drive my cars up onto my hory homemade wooden ramps, then jack up the back of the car with my trolley jack - car is level and theres space to crawl around underneath
Santa's Mega Sale
Santa's TardMe Listings
GTFX: viewtopic.php?t=67655
Postby nile » Mon Nov 15, 2010 5:08 pm
PM maddog for tools, he has mean hook ups. :D
nile
Postby h8wrxs » Mon Nov 15, 2010 5:29 pm
few of my mates drive there cars up onto a few bits of timber just to get the jack underneath the car...
The four seasons in Australia consist of "$&#$% it's hot", "Can you believe how $&#$% hot it is?", "I won't be in today because it is too $&#$% hot" and "Yes, the dinner plate size spiders come inside to escape from the heat."
h8wrxs
Location: travelling to candy mountain with my magical leoplurodon
