Front end of the car wobbles
Postby coolnik12 » Fri Nov 26, 2010 11:28 pm
Hi there,
so i had this problem with my car wobbling alot on high speeds like over 90kms. I had my wheels balanced, the guy said they were pretty bad and he even said that after doing the balancing, the wobbling should stop. But sadly it still does that, but now its a little better than before. It wobbles just over at 100kms now. The guy also mentioned it could be the front shocks if the problem still continues.
What could the problem be?? Help appreciated :D
coolnik12
Postby sergei » Sat Nov 27, 2010 12:06 am
When last time you had wheel alignment done?
Re: Front end of the car wobbles
Postby loudstealthGT-Four » Sat Nov 27, 2010 12:49 am
coolnik12 wrote:Hi there,
blah blah..... The guy also mentioned it could be the front shocks if the problem still continues.
maybe try looking at the shocks, like he said
loudstealthGT-Four
Postby h8wrxs » Sat Nov 27, 2010 2:02 am
wow 8O
The four seasons in Australia consist of "$&#$% it's hot", "Can you believe how $&#$% hot it is?", "I won't be in today because it is too $&#$% hot" and "Yes, the dinner plate size spiders come inside to escape from the heat."
h8wrxs
Location: travelling to candy mountain with my magical leoplurodon
Postby KinLoud » Sat Nov 27, 2010 7:58 am
swap front wheels onto the back
might be one tyre/wheel causing the problem.
Jack up car and spin wheels looking for wonky tread/wheel
borrow a set of wheels
if prob continues check for bent hub
Postby iOnic » Sat Nov 27, 2010 9:35 am
sergei wrote:When last time you had wheel alignment done?
This + check for play in ball joints/tie rods
Postby BZG Wagon » Sat Nov 27, 2010 10:13 am
What do you mean by 'wobbles'?
BZG Wagon
Postby deaf_rattle » Sat Nov 27, 2010 10:19 am
BZG Wagon wrote:What do you mean by 'wobbles'?
or more like?
Postby jondee86 » Sat Nov 27, 2010 11:35 am
There's really no answer to that :)
Cheers... jondee86
Watch this space >>> <<<
jondee86
Postby coolnik12 » Sat Nov 27, 2010 7:13 pm
about 4 months ago?
coolnik12
Postby coolnik12 » Sat Nov 27, 2010 7:14 pm
KinLoud wrote:swap front wheels onto the back
Thanks for the advice, will try swapping the wheels
coolnik12
Postby coolnik12 » Sat Nov 27, 2010 7:19 pm
He said it could be the shocks. I dont think it is the shocks. They seem to be sturdy and not real loose.
coolnik12
Postby Boosted_162 » Sat Nov 27, 2010 8:18 pm
I have the same problem in my GTR, but i suspect its my front tyres as they are pretty old and worn uneven. Gunna get a new set of tyres and get a wheel allignment.
Id agree with swapping front to back and see if theres any change.
Postby h8wrxs » Sat Nov 27, 2010 10:56 pm
it could be anything really, anything from a bent wheel or worn tyre to the suspension or even the wheel alignment
maybe get the alignment done again somewhere different ???
h8wrxs
Postby THA SHZ » Sun Nov 28, 2010 11:38 am
check the tyres first to see if they are separated and then check for buckled wheel also , is the vehicle lowered ? when you say wobbles do you mean steering wheel shakes , whole car shakes or the vehicle is darting ? more information would be helpful to determine the cause 8)
THA SHZ
Postby postfach » Sun Nov 28, 2010 12:35 pm
Could be flat spots on the tires, have you locked up the front wheels at some point?
postfach
Postby deaf_rattle » Sun Nov 28, 2010 3:18 pm
postfach wrote:Could be flat spots on the tires, have you locked up the front wheels at some point?
that would be picked up on wheel balance though
Postby postfach » Sun Nov 28, 2010 3:31 pm
Duh, I'll go back to my cave now :lol:
Actually though, when I think about it, even though you could balance it, it would still cause a vibration à la flintstones wheels, wouldn't it?
First course of action is definitely swap front and rear wheels round, if there are flat spots on the front tires, you'll still feel them when they're on the rear but it won't give the same feedback through the steering wheel.
postfach
Postby Mr Revhead » Sun Nov 28, 2010 5:49 pm
Or car left sitting in the one place for a period of time casuing flat spots. Have had that, balancing didn't fix it. They are in balance, but still have a flat spot on the tread.
Postby THA SHZ » Mon Nov 29, 2010 12:38 pm
not if the guy balancing the wheels wasnt looking for that :wink:
THA SHZ
