Things you wish you knew before starting your first rebuild
Postby Vertigo » Fri Dec 10, 2010 8:42 am
Thought this might be a treasure trove of info that budding mechanics can use to learn from experience :D So, what vital things do you wish you had known about before setting out on this journey? Also, what little bits of info do you think are vitally important that you might consider common sense/knowledge? Doesnt have to be specific to any engine, but if you have something interesting in that regard, please share! This can be during the rebuild, on first start, or during break in.
(4AGE's especially :D!)
TVIS just kicked in, yo!
Vertigo
Postby FANGIN » Fri Dec 10, 2010 8:50 am
Before you even pull the engine out, take pictures of everything and label the parts / loom plugs / vacuum lines etc.
Makes it soo much easier to put everything back together.
And a tidy garage / workshop is a must, you can waste alot of time searching for a tool that could be hidden under a rag or something.
Also, make sure you have or have access to the correct tools for the job.
When I rebuild my first engine (pinto *shudder*) I did none of this and it took me ages to put it back together.
All common sense really.
1998 AE111 Carib - For Sale!
1999 JZS161 GS300 - Tow Wagon
1986 FC3S - 410wkw Drag / Track Toy
FANGIN
Postby Dell'Orto » Fri Dec 10, 2010 10:44 am
Make sure you have EVERYTHING ready before you start...nothing worse than having to run off to buy a specific tool halfway through!
Postby cogent » Fri Dec 10, 2010 10:49 am
more generic advice rather than specifically rebuild advice, but set yourself clear and achievable goals and stick to them, rather than deciding halfway through the rebuild that your 4agte is going to become a clone of bazdas 7agte ;)
cogent
Postby Heylin » Fri Dec 10, 2010 3:09 pm
Ensuring the company you use to rebuild your motor are not a bunch of disorganised incompentent f**k heads.
Heylin
Heylin
Postby eskimo » Fri Dec 10, 2010 3:26 pm
Dell'Orto wrote:Make sure you have EVERYTHING ready before you start...nothing worse than having to run off to buy a specific tool halfway through!
THIS!
"If in doubt, flat out" Colin McRae 1968-2007
Current:2003 Legacy 3.0R Spec B
Previous: ST185 GT4, SW20 MR2, ST206 Curren, AE111 Corolla GT
eskimo
Postby gasman » Fri Dec 10, 2010 4:49 pm
set a realistic time frame and dont brag about it till its done.
"What can possibly go wrong?"
gasman
Postby Akane » Fri Dec 10, 2010 5:07 pm
Wish I knew that most of the engine builders / tuners / mechanics in this country are just f**ktards in overalls, don't know jackshiet and just want your hard earned cash.
Postby AE92-5ONIC » Fri Dec 10, 2010 5:36 pm
Don't have a set budget, you'll always find something else that is F#%k'd.
AE92-5ONIC
Postby Scottie » Fri Dec 10, 2010 7:13 pm
Akane wrote:Wish I knew that most of the engine builders / tuners / mechanics in this country are just f**ktards in overalls, don't know jackshiet and just want your hard earned cash.
You are so cool. Can we be friends.
Scottie
Postby Akane » Fri Dec 10, 2010 7:49 pm
Are you a mechanic and want to work on my car?
Postby gasman » Fri Dec 10, 2010 9:48 pm
looks like you've been made Scottie
gasman
Postby IH8TEC » Sat Dec 11, 2010 8:43 am
Get the parts to do it right the first time
Postby RomanV » Sat Dec 11, 2010 9:32 am
I reckon, spend the $$$ on parts that bolt on to a decent engine block, and leave everything inside alone. (Especially so with forced induction)
You may not make as much power ultimately, however when your engine inevitably poos its pants, you can just get another block, and bolt all the bits back on.
When you've got a $$$$ rebuilt engine that craps itself, you're screwed.
Postby tsoob » Sat Dec 11, 2010 10:26 am
Having built 3 motors now, I'd say if you want a turbo 4agte.
Work out what you want the car to be used for and what kind of power.
Use a decent engine builder to inspect the crank (grind if need be)
Get the block acid dipped and the bores cleaned up profssionally.
I'd suggest ACL race series, ARP main studs and rod bolts
STD toyota head gasket.
Have the head crack tested AND at least upgrade the valve springs
ARP head studs ( I went thru 3 sets of bolts before I changed over)
Make sure you put it together in an environment that youd be happy to see your mother have her knee operated on :D
Use good quality sealant for the sump
Take your time.
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
WHEELS, TYRES & SUSPENSION!
www.platinumwheels.co.nz
tsoob
Postby neo » Sat Dec 11, 2010 1:42 pm
make sure its not your daily driver, as doing it yourself it may be off the road for up-teen months.
Price up all the bits, tools and machining costs, then double it. Ensure you have said cash before you begin.
neo
Postby Bling » Sat Dec 11, 2010 2:06 pm
Surface rust on old cars is never just surface rust. :evil:
Also along the lines of what IH8TEC said, do it once do it right. Or just don't bother.
Postby Vertigo » Sun Dec 26, 2010 8:42 pm
heres one i rediscovered - leave belts on before undoing certain bolts! (such as water pump pulleys)
Vertigo
Postby HachirokuGTV » Tue Dec 28, 2010 7:59 pm
Label parts and corresponding bolts/screws.
Plan, plan, plan.
You don't need 5 sets of wheels for one car, but it's still nice.
HachirokuGTV
Postby MAGN1T » Tue Dec 28, 2010 9:54 pm
Work out why you're having to do a rebuild in the first place. Correct the cause of it first.
Otherwise you'll be doing another and another.
Steve
Computers make you go mad.
MAGN1T
!USER HAS BEEN BANNED!
