Things you wish you knew before starting your first rebuild
Vertigo
Post by Vertigo »
Thought this might be a treasure trove of info that budding mechanics can use to learn from experience :D So, what vital things do you wish you had known about before setting out on this journey? Also, what little bits of info do you think are vitally important that you might consider common sense/knowledge? Doesnt have to be specific to any engine, but if you have something interesting in that regard, please share! This can be during the rebuild, on first start, or during break in.
(4AGE's especially :D!)
TVIS just kicked in, yo!
FANGIN
Post by FANGIN »
Before you even pull the engine out, take pictures of everything and label the parts / loom plugs / vacuum lines etc.
Makes it soo much easier to put everything back together.
And a tidy garage / workshop is a must, you can waste alot of time searching for a tool that could be hidden under a rag or something.
Also, make sure you have or have access to the correct tools for the job.
When I rebuild my first engine (pinto *shudder*) I did none of this and it took me ages to put it back together.
All common sense really.
1998 AE111 Carib - For Sale!
1999 JZS161 GS300 - Tow Wagon
1986 FC3S - 410wkw Drag / Track Toy
Post by Dell'Orto »
Make sure you have EVERYTHING ready before you start...nothing worse than having to run off to buy a specific tool halfway through!
cogent
Post by cogent »
more generic advice rather than specifically rebuild advice, but set yourself clear and achievable goals and stick to them, rather than deciding halfway through the rebuild that your 4agte is going to become a clone of bazdas 7agte ;)
Heylin
Post by Heylin »
Ensuring the company you use to rebuild your motor are not a bunch of disorganised incompentent f**k heads.
Heylin
eskimo
Post by eskimo »
Dell'Orto wrote:Make sure you have EVERYTHING ready before you start...nothing worse than having to run off to buy a specific tool halfway through!
THIS!
"If in doubt, flat out" Colin McRae 1968-2007
Current:2003 Legacy 3.0R Spec B
Previous: ST185 GT4, SW20 MR2, ST206 Curren, AE111 Corolla GT
gasman
Post by gasman »
set a realistic time frame and dont brag about it till its done.
"What can possibly go wrong?"
Contact:
Post by Akane »
Wish I knew that most of the engine builders / tuners / mechanics in this country are just f**ktards in overalls, don't know jackshiet and just want your hard earned cash.
AE92-5ONIC
Post by AE92-5ONIC »
Don't have a set budget, you'll always find something else that is F#%k'd.
Scottie
Post by Scottie »
Akane wrote:Wish I knew that most of the engine builders / tuners / mechanics in this country are just f**ktards in overalls, don't know jackshiet and just want your hard earned cash.
You are so cool. Can we be friends.
Contact:
Post by Akane »
Are you a mechanic and want to work on my car?
gasman
Post by gasman »
looks like you've been made Scottie
Post by IH8TEC »
Get the parts to do it right the first time
Post by RomanV »
I reckon, spend the $$$ on parts that bolt on to a decent engine block, and leave everything inside alone. (Especially so with forced induction)
You may not make as much power ultimately, however when your engine inevitably poos its pants, you can just get another block, and bolt all the bits back on.
When you've got a $$$$ rebuilt engine that craps itself, you're screwed.
tsoob
Contact:
Post by tsoob »
Having built 3 motors now, I'd say if you want a turbo 4agte.
Work out what you want the car to be used for and what kind of power.
Use a decent engine builder to inspect the crank (grind if need be)
Get the block acid dipped and the bores cleaned up profssionally.
I'd suggest ACL race series, ARP main studs and rod bolts
STD toyota head gasket.
Have the head crack tested AND at least upgrade the valve springs
ARP head studs ( I went thru 3 sets of bolts before I changed over)
Make sure you put it together in an environment that youd be happy to see your mother have her knee operated on :D
Use good quality sealant for the sump
Take your time.
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
WHEELS, TYRES & SUSPENSION!
www.platinumwheels.co.nz
neo
Contact:
Post by neo »
make sure its not your daily driver, as doing it yourself it may be off the road for up-teen months.
Price up all the bits, tools and machining costs, then double it. Ensure you have said cash before you begin.
Contact:
Post by Bling »
Surface rust on old cars is never just surface rust. :evil:
Also along the lines of what IH8TEC said, do it once do it right. Or just don't bother.
Vertigo
Post by Vertigo »
heres one i rediscovered - leave belts on before undoing certain bolts! (such as water pump pulleys)
HachirokuGTV
Post by HachirokuGTV »
Label parts and corresponding bolts/screws.
Plan, plan, plan.
You don't need 5 sets of wheels for one car, but it's still nice.
MAGN1T
!USER HAS BEEN BANNED!
Post by MAGN1T »
Work out why you're having to do a rebuild in the first place. Correct the cause of it first.
Otherwise you'll be doing another and another.
Steve
Computers make you go mad.
Post Reply
