A gear knob with no thread
Postby QikStarlie » Tue Dec 28, 2010 4:56 pm
its only plastic just drill it. and yeh all toyotas ive come accross have been m12
QikStarlie
Postby Bling » Tue Dec 28, 2010 5:20 pm
Tagged wrote:I was wondering if drilling M12 thread onto an existing M10 thread would screw the whole thing up.....
Just drill it a bit bigger and try screw the gearknob on, if you can't, drill it a bit bigger. Do this until it fits TIGHT, no point it being loose as it will come off when driving so only drill it just enough so you can fit it on. It's only plastic so the gearstick should screw into it without needed to have it tapped.
Postby Tagged » Tue Dec 28, 2010 6:17 pm
hmmm i think you guys are right. and ok I'll try it out and have the result up here~ lucky we do have drills in our house haha
Tagged
Postby Tagged » Wed Dec 29, 2010 1:59 am
tried drilling with both 9 and 10mm drills. no luck....still wont go in.
Sadly the next size is 12mm which im sure its too big......so should I try and get a 11mm drill bit?
Tagged
Postby Rob_GTZ » Wed Dec 29, 2010 8:13 am
Required thread is M12x1.25, standard on Toyota Shifters
I'll tap it out to the correct thread for you, if you can wait till the weekend
Rob_GTZ
Postby thornz » Wed Dec 29, 2010 10:00 am
Just drop into a workshop somewhere, will take them 10 minutes, have usually found in the past they will do it for free as well when i have needed stuff tapped.
thornz
Postby Tagged » Wed Dec 29, 2010 12:07 pm
Rob_GTZ wrote:Required thread is M12x1.25, standard on Toyota Shifters
wow thanks man thats awesome~! should I go somewhere to meet you or....?
Tagged
Postby Rob_GTZ » Wed Dec 29, 2010 6:17 pm
021 355 803
Give me a text & we can sort it out
Rob_GTZ
Postby Tagged » Wed Dec 29, 2010 10:21 pm
Rob_GTZ wrote:021 355 803
cool will do tmr~
Tagged
