Newb question about ignition timing
Postby gasman » Sat Jan 08, 2011 4:08 pm
how does one go about checking ignition timing with a timing light on a coil on plug type engine since there is no HT lead?
"What can possibly go wrong?"
gasman
Postby jondee86 » Sat Jan 08, 2011 5:08 pm
Just making this up, but if you had an old plug lead and cut it
short, you could fit it between the COP and the plug ??
Cheers... jondee86
Watch this space >>> <<<
jondee86
Postby iOnic » Sat Jan 08, 2011 5:36 pm
Put the inductive clamp from your timing light around the trigger wire to the #1 coil. Good timing lights can pick up the low voltage trigger pulses. If not some timing lights can pick up the signal from the coil itself by just having the inductive clamp on the coil somehow.
Postby Burning Angel » Sun Jan 09, 2011 4:49 pm
Not sure what car you have but nissans have a loop of wire specifically for hooking an inductive clamp up to.i think it's near the ignitor. Otherwise just try one of the other suggestions
1984 SRP61 Starlet
1999 WRX Type RA
Burning Angel
Users browsing this forum: Bing [Bot], Google [Bot] and 11 guests
