Seatbelt jamming after removal.
Postby gleem » Mon Jan 10, 2011 6:33 am
seat belts worked fine prior to removal and now, 6 weeks later they wont pull out? all of them are like that. does it need to be fitted or something but i dont see why
thanks
gleem
Postby fivebob » Mon Jan 10, 2011 6:38 am
They probably need to be at the installed angle to work.
Postby strx7 » Mon Jan 10, 2011 6:46 am
fivebob wrote:They probably need to be at the installed angle to work.
either that or you've screwed them by letting them retract too far. both are common complaints from people who know nothing about seatbelts
Postby Quint » Mon Jan 10, 2011 8:53 am
If they've retracted too far, you can get them out again by putting them on the right angle and 'jiggling' the belt. I've managed to get a few jammed ones out this way. Takes about 45mins of aggravation though.
Quint
Postby .:O4AGTZ:. » Mon Jan 10, 2011 10:11 am
you arent trying to open them on a hill are you lol
.:O4AGTZ:.
Postby z0ton » Mon Jan 10, 2011 6:17 pm
Pretty much all seat beats are only designed to work on one angle. Put it flat up against something and slowly spin it while pulling on the belt, it shouldn't be hard to get out...
z0ton
Postby thegreatestben » Mon Jan 10, 2011 11:37 pm
What kind of car, generally drivers belts are either 9090 or 8090.
Those are the two angles required for the belt to work.
thegreatestben
Postby gleem » Wed Jan 12, 2011 6:42 am
honda ek civic
gleem
honda ek civic
gleem
