Has this fuel gone bad?
Postby cozmoid » Fri Jan 14, 2011 4:33 pm
I had this same problem with my 2T GEU and it was the ECU not getting very good signal quality from the coil for the injector pulse. Turns out the wire was a little loose!
You could also have a very sorry fuel pump and fuel filter
Sorry but no definate answers but maybe something to check.
I am pretty sure that if you take the cover off your ecu all the plug codes are there and the injector signal to the ECU should be easy to find. Labelled INJ. Just put a test light on it and turn it over. It should blink nice and steady and consistent.
There is also a little led things you can plug in to your individual plugs at the injectors to check if they are firing consistently too.
Ae70/Te71 Hybrid
viewtopic.php?t=54364
cozmoid
Postby sergei » Fri Jan 14, 2011 4:36 pm
cozmoid wrote:I had this same problem with my 2T GEU and it was the ECU not getting very good signal quality from the coil for the injector pulse. Turns out the wire was a little loose!
That sounds like analogue ECU.
If it backfires in the intake and pushes against starter it is most likely timing issue (too far advanced), or position signal too noisy (are you running a link?).
Postby cat007 » Fri Jan 14, 2011 4:55 pm
MAGN1T wrote:
cat007 wrote:
edit: Also sometimes when initially cranking, it tries to fire against the starter, but only at the start
You get that when ignition timing is too far advanced.
Steve
Hmm ok. I've checked the static timing and it's fine and the map is the same one as it was tuned for. So not sure what the hell is happening.
I'll lower the overall timing and see what happens
Postby cat007 » Fri Jan 14, 2011 7:22 pm
Running an EMS stinger ECU.
I'll recheck the timing however nothing has changed since it was last running.
It only fires against the starter on the first initial crank then it doesn't do it again...
Postby tsoob » Fri Jan 14, 2011 9:21 pm
sounds like timing to me.. is the base timing in the ecu setup right? I remember setting up my new computer was a real prick to get right
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
WHEELS, TYRES & SUSPENSION!
www.platinumwheels.co.nz
tsoob
Postby cat007 » Sat Jan 15, 2011 10:05 am
tsoob wrote:sounds like timing to me.. is the base timing in the ecu setup right? I remember setting up my new computer was a real prick to get right
Yeah I checked the static/base timing and it's spot on. I'm going to take the loom out again and check that all the plugs are on ok and make sure there's nothing that could be introducing noise to the signal wires...
Postby tsoob » Sat Jan 15, 2011 10:45 am
yep cas wiring was also a $&#$%, the signal had 2 be reveresed or something silly like that, as in the ecu was reading it backwards.
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
tsoob
Postby cat007 » Sat Jan 15, 2011 11:27 am
tsoob wrote:yep cas wiring was also a $&#$%, the signal had 2 be reveresed or something silly like that, as in the ecu was reading it backwards.
Oh yeah? Like the fire edge is set to falling and it should be rising or something?
Postby cat007 » Sat Jan 15, 2011 7:54 pm
Here's a video of what happens after it finally starts and I try and rev it....
http://www.youtube.com/watch?v=a6C3K6j7eB4
Postby MAGN1T » Sun Jan 16, 2011 9:29 am
AFR is all over the place.
Maybe your computer has got spiked?
Did you save a backup to reload it with?
Steve
Computers make you go mad.
MAGN1T
!USER HAS BEEN BANNED!
Postby cat007 » Sun Jan 16, 2011 10:28 am
MAGN1T wrote:AFR is all over the place.
Steve
I've reloaded various maps on there, including one I made when I first put the ECU in, which did allow the car to start and run pretty well - but even with that map it doesn't run.
Here's a video of what happens when cranking:
http://www.youtube.com/watch?v=ZHcoFiJ8wKQ
I'm having issues with the wideband cutting out when cranking, I think it's a voltage drop thing, but that should've have any effect on the ECU as the wideband is only monitoring the AFR, and not adjusting it.
Postby Bling » Sun Jan 16, 2011 10:32 am
It's not an issue with the battery?
Postby cat007 » Sun Jan 16, 2011 10:42 am
BZG|Bling wrote:It's not an issue with the battery?
How so?
Postby MAGN1T » Sun Jan 16, 2011 12:13 pm
Did you check the fuel pressure and the flow out of the reg?
Steve
MAGN1T
Postby cat007 » Sun Jan 16, 2011 12:31 pm
MAGN1T wrote:Did you check the fuel pressure and the flow out of the reg?
Steve
Fuel pressure is good and flow out of the fpr is good
Postby cat007 » Sun Jan 16, 2011 3:08 pm
Changed the plug gap, not sure what too as I don't have a feeler gauge, but once I did that the engine starts pretty easily now. Not as easy as it used to, but it at least starts now. Trying to rev the engine however will result in the same popping and farting around as before - I 'think' it could be a little better now, but hard to say....
I guess I should gap the plugs properly and see if that helps.
0.8mm should be about right?
Postby cat007 » Mon Jan 17, 2011 7:27 pm
Ok so gapped the plugs to 0.8, issue remains
Gapped them to 0.7mm and there's no difference
Running out of ideas here
Maybe the ignitor is bung or the coils perhaps? Mitsi V6 ignitor with 3x7M-GTE coils.
Postby Bling » Mon Jan 17, 2011 8:00 pm
How so?
Just thought if the battery was on its way out it might be giving ya ecu grief, which then gives you grief .
Postby cat007 » Mon Jan 17, 2011 8:38 pm
BZG|Bling wrote:
How so?
Haha. that it does my friend. That it does
But seriously, how could the battery be giving me grief? Inconsistent voltages or something?
Postby sark.inc » Mon Jan 17, 2011 9:50 pm
i thought the AFR should be around 14 or so, not 20+ at idle :s
sark.inc
