Easiest way to get engine out of boot?
Postby siren676 » Tue Jan 25, 2011 1:06 pm
I have just bought an engine. Its on a pallet in my boot and i cant see how im going to get it out on my own.
Any ideas?
its a 5e-fhe so only about 110kg's
siren676
Postby Stu- » Tue Jan 25, 2011 1:07 pm
Couple of bit of wood as a ramp and slide it down
Project Thread
Stu-
Postby siren676 » Tue Jan 25, 2011 1:16 pm
Thats what i was thinking.
Ill try find some suitable bits of wood and ill update how it goes
siren676
Postby Leon » Tue Jan 25, 2011 1:21 pm
it isn't worth risking hurting your back. Wait until you can get some mates around.
Postby tsoob » Tue Jan 25, 2011 1:28 pm
angle grind the boot floor away :twisted:
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
WHEELS, TYRES & SUSPENSION!
www.platinumwheels.co.nz
tsoob
Postby h8wrxs » Tue Jan 25, 2011 1:32 pm
shoot up some steroids :twisted:
The four seasons in Australia consist of "$&#$% it's hot", "Can you believe how $&#$% hot it is?", "I won't be in today because it is too $&#$% hot" and "Yes, the dinner plate size spiders come inside to escape from the heat."
h8wrxs
Location: travelling to candy mountain with my magical leoplurodon
Postby Bling » Tue Jan 25, 2011 1:35 pm
Jack the front up till engine has located itself on the ground. :lol:
I've lifted a 4k out of a ke70 wagon before by myself, helped the wagon was on the ground, but still not fun! As Leon says, not worth the back injury!
Postby GDII » Tue Jan 25, 2011 1:54 pm
I can move a 2E engine minus gearbox around by myself but you would need atleast 2 people to get it out of a car.
How did you get it in?
I think getting some decent planks of wood that won't bend too much and sliding the pallet out on them would work well like Stu- said. That way it won't run away on you if you don't make the ramp too steep.
1990 SW20 MR2
Previous 1990 EE90 Corolla
GDII
Postby Leon » Tue Jan 25, 2011 2:13 pm
chain it to a post, then drive away really fast.
Or, use one of those stretchy 4x4 tow strops, attach that to the garage wall, drive away really fast and get bonus points if you can get the engine to go clear through the garage wall.
Bonus points if you can get it to land in the neighbour's swimming pool.
Postby sik_gt_starly » Tue Jan 25, 2011 2:17 pm
smoke some meth and wait a couple minutes youll be able to do it with one hand tied behind your back.
if that fails get a friend or 2 depending on how lacking in strength you are. 2 people should be able to lift a 5e no worries
sik_gt_starly
Postby siren676 » Tue Jan 25, 2011 2:46 pm
Well its out.
I couldnt find a piece that was long enough so i had to try a different approach.
GDII wrote:...
Mainfreight put it in with a forklift
To cut long story short on how i got it out, i've just drawn a picture.
siren676
Postby .:O4AGTZ:. » Tue Jan 25, 2011 2:50 pm
that is a good effort!
.:O4AGTZ:.
Postby GDII » Tue Jan 25, 2011 3:01 pm
siren676 wrote:Well its out.
GDII wrote:...
I figured that was how it was put in. Being on a pallet.
Thats a clever way of getting it out.
1990 SW20 MR2
GDII
Postby Boost_4_Life » Tue Jan 25, 2011 3:28 pm
would have been better if you used a complex pulley system...
'83 KP starlet rally car, 20v powa!
The rally beast
The rally beast again!
Boost_4_Life
Postby tsoob » Tue Jan 25, 2011 3:32 pm
THAT is an AWESOME picture!!!!!
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
tsoob
Postby siren676 » Tue Jan 25, 2011 3:42 pm
Boost_4_Life wrote:would have been better if you used a complex pulley system...
i was actually considering swinging it out of the boot :lol: but didnt trust the supports in the roof or my own calculations.
Thanks tsoob, i couldnt think how to describe the setup so i thought a picture would be better.
siren676
Postby eskimo » Tue Jan 25, 2011 4:23 pm
tsoob wrote:THAT is an AWESOME picture!!!!!
Agreed, the car even has a boot spoiler. Good effort on both the drawing and removing the motor :lol:
"If in doubt, flat out" Colin McRae 1968-2007
Current:2003 Legacy 3.0R Spec B
Previous: ST185 GT4, SW20 MR2, ST206 Curren, AE111 Corolla GT
eskimo
Postby Adamal » Tue Jan 25, 2011 5:12 pm
Use some rope to tie the pallet to a pole or something. Rev it to the limiter and chuck it in gear. That should get it out.
Postby tsoob » Tue Jan 25, 2011 5:15 pm
car needs mags BTW :wink:
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
tsoob
Postby rollaholic » Tue Jan 25, 2011 5:31 pm
uh, and tyres
